gib key removal
this thread has 5 replies and has been viewed 12834 times
Old 12-25-2004, 03:40:28 PM
Tanner Remillard's Avatar
Images: 10
Default gib key removal
I know this has come up several times before but I am having some serious problems with the gib key on my 4 H.P. Stover T. I have tried the slide hammer trick, the puller trick, pushing the flywheel on farther so it will loosen the key trick, and none of them have made it budge. Any one else have any genious ideas?? My merry christmas is'nt being very merry
Old 12-25-2004, 04:00:12 PM
BobRR BobRR is offline
Default Re: gib key removal
How about the drill trick? BobRR
Old 12-25-2004, 04:04:45 PM
Ken Erman Ken Erman is offline
Here is what i used...
http://community.webshots.com/album/81060592eqzEHv
Old 12-25-2004, 05:20:27 PM
Harry's Avatar
Images: 312
Gib keys are the most miserable thing on an engine!
I put the whole flywheel and crank on the bench and grabbed the head in my vise and used a chisel to separate it from the crankshaft.
http://www.old-engine.com/fuller.htm
Old 12-25-2004, 05:45:39 PM
Images: 10
Thanks Ken, that worked pretty good. Once I found a pipe big enough in my iron pile to fit over the crankshaft and the bolt, I cut it to lenth and cut a piece of half inch plate to fit on the end of the pipe for the bolt to run through, I used a half inch breaker bar and could'nt get the key to move with that and all my arm strenth, so I got the 3/4 in. air gun out and it came right out. Sometimes you just have to tell them old engines who is boss I guess.
Old 12-26-2004, 07:26:33 PM
Smile Re: gib key removal
I'd love to take credit for the idea, but i got it here on Harry's page.
Pin removal Ray Cardoza Antique Gas Engine Discussion 2 03-27-2008 03:06:34 PM
Name/SN tag removal Greg Shipley Antique Gas Engine Discussion 5 11-07-2006 12:35:07 PM
tar removal DanR Antique Gas Engine Discussion 8 02-26-2006 06:45:07 AM
Key removal Don C. Wiley Antique Engine Archives 11 11-17-2002 09:09:01 AM
cam removal 6hp JD Marty Antique Engine Archives 3 08-23-2002 11:54:06 PM
