New Member of the Twin City Twin Cam Fraternity
this thread has 22 replies and has been viewed 1706 times
Old 04-14-2017, 09:06:52 PM
J Ware J Ware is offline
Default Re: New member of the Twin City twin cam fraternity
I took a look at the twin cam today, I made the decision after I got the tractor home that I'm going to switch it to a hand clutch. To do so I got a clutch handle off a TC 21-32 and I just need to fab a plate to bolt to the handle and drill a hole to hook the clutch linkage to. Very simple. I also picked up a Bosch ZR4 mag, but i do have to change the rotation of the impulse,luck for me Bosch seen to it you just have to reverse the parts of the impulse according to the appropriate markings. Now just to get at itand get it done. Just as soon as the Cletrac repower is finished. Jim
Old 04-14-2017, 11:35:03 PM
Phil Johnson's Avatar
If I remember right, I think you also need to change the point plate for counter clockwise rotation.
It'll be done in good time---impossible might take a little longer!
The Following 3 Users Say Thank You to Phil Johnson For This Post:
Old 04-14-2017, 11:41:07 PM
Jeff Blaney Jeff Blaney is offline
Congrats on the new tractor. Any idea where the new sheet metal came from? I am in need of a set of fenders for my FTA.
Old 04-15-2017, 07:27:57 AM
ajs2744TC ajs2744TC is online now
Believe your right Phil. I made that assumption and every time I advanced the mag it would quit. Had to change point plate and problem solved.
Old 04-15-2017, 07:30:13 AM
I'll have to compare it to the one in the mag for the cross motor Minnie, thanks for the info Phil. Jeff , I think the fenders were made by Merle Holderman aka Tired Iron Farms repo sheet metal before he passed away. Merle made a good products at prices that people could afford. Check enginads for Bobs ad in Harrison Mi.
Old 04-16-2017, 08:32:10 PM
Default Re: New Member of the Twin City Twin Cam Fraternity
Ajs,did you use the existing plate jus flip it over or have to get a different one.
I got the hand clutch all finished, pic 1 is the handle I got from Beiwers, pic2 is the piece I made and attached to the handle. Pic 3 and 4 is it installed on the tractor. Jim
Old 04-17-2017, 12:54:28 AM
You can't flip the plate. You have to get the one for CCR.
Old 04-17-2017, 08:47:11 AM
Phil's right! Can't flip. And if I remember right there was an A stamped behind mine for anti. Believe Minneapolis used clockwise rotation.
Old 04-17-2017, 09:55:46 AM
Lets see if these pics will load
ID:	280230   Click image for larger version
ID:	280231   Click image for larger version
ID:	280232   Click image for larger version
The Following User Says Thank You to J Ware For This Post:
Old 09-05-2017, 09:32:29 PM
Yesterday I pulled the 17-28 out that I bought about a year ago. I haven't heard it run yet. I got the new mag installed and belted it up, but could get oil pressure. Removed plug on oil pump and filled with oilseveral times but still no oil pressure. Any advice of where to start. Going to drain oil and check suction screen.
I also picked up a wheeler schebler carb for it also. Jim
Twin City 17-28...My Intiation into the Twin Cam Faternity! Mark Schneider Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 109 11-19-2017 11:39:07 PM
Twin City Big Twin Cam up for Sale Mark Schneider Live Auctions of Engines, Tractors and Old Iron 27 03-19-2017 10:58:08 PM
Twin City rhawke Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 24 11-15-2015 01:14:51 AM
Twin City Help Ben Zimmerer Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 02-04-2012 07:39:27 PM
Two more Twin City's Phil Johnson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 21 08-17-2010 04:28:27 PM
