Military 3kw 4A032 Engine Question..
this thread has 4 replies and has been viewed 5513 times
Old 08-04-2005, 08:26:22 AM
FredRoary's Avatar
FredRoary FredRoary is offline
Question Military 3kw 4A032 Engine Question..
Guy's,
My 3kw Military Genset would not start for me last night. After some trouble shooting, I think it is the fuel pump, When I disconnect the fuel line from the Output of the pump and prime with the lever, I get nothing,, I even hooked up an external fuel tank and did a gravity feed into the fuel pump,, still nothing, even when I pump the primer. also,, are these fuel pumps similiar to a fuel pump on a Chevy V8 ?? reason I ask that,, is I think I smell fuel on the oil dipstick, and I remember a 1979 Chevy Truck that I owned had the fuel pump go out on it and fuel leaked into the Engine Block into the oil.
thnx!
Old 08-04-2005, 10:21:28 AM
Elden DuRand's Avatar
Images: 11
Exclamation Re: Military 3kw 4A032 Engine Question..
Originally Posted by FredRoary
Guy's,
thnx!
Fred:
You might as well assume that the diaphragm of the pump is leaking and has contaminated the engine oil.
Most pumps (if you can't find a new one or convert to gravity feed) can be disassembled and, if the material is at hand, a new diaphragm can be made.
Take care - Elden
http://home.cybertron.com/~edurand
Old 08-04-2005, 03:33:23 PM
K D Redd K D Redd is offline
Default Re: Military 3kw 4A032 Engine Question..
I had problems with the fuel pump on the same type of genset the fire dept has. The valves were stuck in it. You might check out the fuel pump rebuild kit Kohler offers in their parts system. I have found it will rebuild many of these small fuel pumps.
Kent
Old 08-04-2005, 10:30:01 PM
Jim McIntyre's Avatar
New fuels pumps for the 4A032 are $12.50 here:
http://www.saturnsurplus.com/4a032.htm
Old 08-05-2005, 01:28:07 PM
FredRoary's Avatar
got a new fuel pump on the way from Saturn,
thanx for the help guys!!
Military Air Compressor with Briggs N Engine Jonathan Widelo Small Air Cooled Gasoline Engines 12 03-19-2013 10:13:08 PM
Teledyne Mil Surplus Generator, 4A032-4 Elementfe Generators & Electric Motors General Discussion 13 07-20-2010 05:34:03 PM
Military 4A032-4 Engine notmuch Small Air Cooled Gasoline Engines 9 07-03-2010 12:39:38 AM
Question about Military 10 KW generator Paul Van Sickle Generators & Electric Motors General Discussion 1 04-12-2007 11:08:41 AM
Military 3kw genny starter question. FredRoary Generators & Electric Motors General Discussion 5 05-11-2005 09:39:48 AM
