Teledyne Mil Surplus Generator, 4A032-4
this thread has 13 replies and has been viewed 13126 times
Old 01-24-2007, 06:37:35 PM
Elementfe Elementfe is offline
Default Teledyne Mil Surplus Generator, 4A032-4
Anybody know of a source for a manual for this generator? I got two that have sat for years, need carb cleaning etc.
Best would be a downloadable PDF or similar file, but any leads would be much appreciated.
Thanks!
Andy
Old 01-25-2007, 08:42:17 AM
JBittnerSr JBittnerSr is offline
Default Re: Teledyne Mil Surplus Generator, 4A032-4
I'll check the Cd I have with manuals this afternoon. I may have it
Old 01-25-2007, 08:43:26 AM
That is the 3KW unit. Correct?
Old 01-25-2007, 03:34:46 PM
Right, 2 3kw units, one made 1989, one not sure.
Wild guess is that the fuel pump may not be pumping- it would make sense to kind of know how it's put together before removing random shrouds and such
Andy
Old 01-25-2007, 11:07:06 PM
Images: 12
Andy, I think this place has what you need, here's a link to click on.
http://www.saturnsurplus.com/
Old 01-26-2007, 01:04:40 PM
K D Redd K D Redd is offline
I have found that a fuel pump kit for the fuel pump used on Kohler engines will repair most of the fuel pumps used on small engines. The kit is no longer available in the Kohler parts network but you can find one at: www.outdoordistributors.com
Kent
Old 10-05-2009, 11:20:10 AM
mdlbldrmatt135 mdlbldrmatt135 is offline
Any idea as to the kit number? the new gas (with Ethanol) seems to be eating the diaphragms. I have a couple to rebuild.
Old 10-06-2009, 08:33:41 AM
As I said in my post of 18 months ago, THE KIT IS NO LONGER AVAILABLE from Kohler. I have heard but I have NO personal knowledge that in the ONAN parts system there is a kit available. Try P/N 149-0526. That said, ALL of the small square mechanical pumps are the same except for the pump arm. You can disassemble the pump. Push down on the diaphragm, turn 90 degrees and remove the diaphragm. Then install the diaphragm in the pump you need to be in working order. The pump tops that contain the hose connections and check valves will interchange. Complete pumps are available for a variety of engines mainly the K, M and KT series Kohlers. The pump arm differ between the K and KT series Kohlers. On the M series the pump arms are different between the single cylinder and twin cylinder engines.
The is a down loadable PDF Manuel for the MEP-16 generators but it mostly is towards the generator section. I have set-up a MEP-16/4A032 engine for LP fuel. Search the Mobile Power sub-form for the topic MEP-16 ? and pix.
Kent
Old 02-01-2010, 06:47:23 PM
parssonsba parssonsba is offline
If anyone is interested, I have the operators manual and IPC for the 4A032 in PDF format. Just drop me a line if you need it!
Brett
Old 03-31-2010, 01:47:28 PM
loves small engines loves small engines is offline
Hi everyone. I've been lurking for a while and am ready to post. I've found so much information that is very much appreciated. I would like a PDF of the instruction manual for the 4A032 if it is still available. I just bought a 4A032 generator and am very excited about bringing it home. I haven't heard it run but I've been assured that it does. Thanks in advance for the PDF and also to the many posters that that have posted a lot of info.
Last edited by BTPost; 03-31-2010 at 01:59:34 PM. Reason: I would suggest you PM "parssonsba" ...
Military 4A032-4 Engine notmuch Small Air Cooled Gasoline Engines 9 07-03-2010 12:39:38 AM
Teledyne WFI hotwire Generators & Electric Motors General Discussion 5 01-30-2007 04:03:05 PM
Help with old army surplus generator Hal Davis Generators & Electric Motors General Discussion 1 07-31-2006 08:35:36 PM
Army surplus generator question Clark Stewart Generators & Electric Motors General Discussion 1 05-31-2006 11:39:12 PM
Military 3kw 4A032 Engine Question.. FredRoary Generators & Electric Motors General Discussion 4 08-05-2005 01:28:07 PM
