Two more Twin City's
this thread has 21 replies and has been viewed 3426 times
Old 08-08-2010, 09:02:36 PM
Phil Johnson's Avatar
Default Two more Twin City's
I brought home a couple more Twin City tractors this weekend. One is another early 12-20 and the other is a 17-28 parts tractor. The 12 -20 is in nice shape except for the fenders. The engine is loose and seems clean inside. Transmission shifts very nicely thru all gears and the drive train seems to have not a lot of wear. It has the early Pierce governor and the early cast valve cover vent. The front axle and steering is very tight with none of the usual slop. I think it is considerably better shape than the earlier one which came from the old log barn. Shouldn't take much to get it running. Oh, and the large wasp nest will have to go!!
The 17-28 is a parts tractor and has a lot of good parts. .
ID:	84545   Click image for larger version
ID:	84546   Click image for larger version
ID:	84547   Click image for larger version
Old 08-08-2010, 10:41:22 PM
Jon Nessel's Avatar
Jon Nessel Jon Nessel is offline
Default Re: Two more Twin City's
I think it's time for someone not to let Phil off his leash anymore! At least it's not Rumelys Phil! Another good find by the looks of things at any rate.
Old 08-09-2010, 01:10:27 AM
ssimntih's Avatar
ssimntih ssimntih is offline
Images: 59
you should save that nest! scrape it off best you can and spray it with spray shellac
Old 08-09-2010, 09:27:13 AM
Maybe I should just leave it on there and shellac it as it's wrapped right around the spoke.
Old 08-09-2010, 11:05:33 AM
Jeff Blaney Jeff Blaney is offline
Nice find. I have seen a couple of these smaller Twin Cities in person and in pictures. I have noticed some differences between them. Some have the govenor mounted directly at the timing gear housing and some like this one have all the linkage first and the govenor up top. Is this an early/late 12-20 production feature or a 17-28 feature?
These tractors are very rare birds in my neighbourhood. Is there a real quick way to tell a 12-20 from a 17-28 other than the serial number?
Old 08-09-2010, 11:16:21 PM
Jeff; The small high mounted governor is the Pierce governor that was used on the early 12-20 tractors. The lower mounted one was the Twin city governor that was fitted partway through 12-20 production.
Here is the link to Tony Thompson's excellent Twin City site for a lot more good info.
http://twincitytractors.tripod.com/index.htm
Old 08-10-2010, 12:18:28 AM
ssimntih's Avatar
Images: 59
boy would that ever be the talk of a show. lol if you could keep every little kid from poking it.
Old 08-10-2010, 12:37:27 AM
Interesting tractors and nest. The white faced hornets make those nests. Keep it there.
Old 08-10-2010, 01:38:10 PM
Brothers Clemens's Avatar
Phil,
That is not only a wasp nest but an hole nest of Twin City’s.
Amazing scene.
Phil you seems to know a lot about The Twin City as a tractor collector.
Al arround 15 years we have a Twin City 17-28, as you can see on the next 2 pictures.
The Air intake of this tractor (picture 2) looks a little bit rare.
Do you think its original.
Chris
ID:	84703   Click image for larger version
Old 08-10-2010, 10:02:18 PM
Rick Schmitz Rick Schmitz is offline
Chris
I don't think that is original.
My 12/20 came with a similar air cleaner that someone told me most likely came off of a Minneapolis Moline of some sort.
Name:	TC rt side.jpg
The Following 2 Users Say Thank You to Rick Schmitz For This Post:
Maytag 72 twin Matt McGivney Small Air Cooled Gasoline Engines 10 12-07-2009 11:46:23 PM
Head lines in "The Derrick" Oil City's local newspaper Bruce Golden Antique Gas Engine Discussion 1 08-19-2009 07:56:25 PM
Neptune Twin Cyl. Jerry Lancaster Antique Gas Engine Discussion 12 02-15-2009 12:08:01 PM
It's a TWIN!!! New Way Tim Christoff Antique Gas Engine Discussion 8 02-09-2009 05:03:09 PM
17-28 ty twin city Bear Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 12 01-14-2006 12:00:12 PM
