Go Back   SmokStak > SmokStak® Support and Information > How to use this web site:
How to use this web site: Registering, passwords, navigating, subscribing and getting the most out of this web site.
Making formed Charts on Smokstak
this thread has 0 replies and has been viewed 77 times
Old 03-29-2018, 11:58:19 PM
Images: 312
Default Re: looking char(x) to make add series of spaces to text on stak
Charts Like This?
Overhead valve engines
ModelHPIntroduction DateWithdrawn DateComments
VA219291935Overhead valve air cooled (1st Lauson “small engine” built)
VR219291935VA but Water cooled with radiator
VW219291935VA but water cooled with water tank, sold under “Alpha DeLaval” lable
UA319331945Overhead valve, upgraded model of VA
UR319331935Overhead valve, upgraded model of VR
UW319331940Overhead valve, upgraded model of VW
UAS19331940Overhead valve, replaced VA and UA
UWR419331940Minor version change from UW ?
ZW19351937Like UW but larger ?
ZWR?19351940?
1st generation design engines, all L-Head design
RA½19301933Air cooled
RAB½19301933Same as RA but battery ignition
RAU¾19301933Larger version of RA suction carb. standard, optional float carb.
RAY119301941Larger version of RAU float carb. standard
LA19301935Larger version of RAY
LWR19331945Based on LA but water cooled with radiator
LW19331935Marine version of LWR, water cooled
LB219351945Replaced LA, air cooled
LBM219401945Marine version of LB, no governor, air cooled
LF1935?Replaced LW, marine engine water cooled
LFR19351945LF with radiator
2nd generation design engines, all L-Head design
RLA¾19351945Air cooled, built for military ?
RLB¾19351937Like RLA, built for washing machine use
RLC¾19371951Civilian version of RLA ?, float or suction carb.
RLE¾1937?Looks like RLA ?
RLM¾19401945Marine version of RLC, no governor, air cooled
RSC19371951Larger version of RLC, suction or float carb., air cooled
RSM19401951Marine version of RSC no governor, air cooled
RC19401951Water cooled version of RSC
RCM19401945Marine version of RC, no governor
TLC19371951Larger version of RSC, air cooled
TLM19401945Marine version of TLC, air cooled
H-219451957Oil test engine
PAC4 ¼19461951Larger version of TLC, air cooled
PPM19481951Marine inboard water cooled
LMC¾19481951Replaces RLC ?, air cooled
LMH119511958Upgrades LMC
LMV119511958Vertical shaft version of LMH
RSH219511960+Upgrade to RSC
RSV219511958Vertical shaft version of RSH
V219561958Vertical shaft RSH, flush mount
R219561958Vertical shaft RSH with addtl. horizontal PTO
55S19511958Economy version of RSH ?, suction carburetor
55A219511958Economy version of RSH ?, float carburetor
55AB219511958Economy version of RSH ?, float carburetor
TLH319511960+Upgrade to TLC
TLV319561958Vertical shaft version of TLH
PAH19511958Upgrade to PAC
PAX19561958Like PAH, external magneto
(P25 – P44)19561960+Upgrade to PAX
3rd generation design engines, all L-Head design
SLV219541958Alloy block vertical shaft
VA19561958SLV with larger bore
Instructions Below in Microsoft Word:
Charts and Tables on Smokstak Harry Test Board 1 03-30-2018 08:34:19 AM
Making formed Charts on Smokstak Harry How to use this web site: 0 03-29-2018 11:58:19 PM
Mollier Charts Gary K Steam Stationary Engines, Traction Engines, Steam Boats 3 10-10-2009 09:43:30 PM
getting boiler parts formed HalfKeck Steam Stationary Engines, Traction Engines, Steam Boats 4 09-19-2009 11:32:33 AM
