Antique Steel Wheeled Mechanical Plows...History, Weed Finds, Prices, Parts, Etc.
this thread has 373 replies and has been viewed 88134 times
Old 01-08-2014, 08:04:43 PM
IWL BCNU IWL BCNU is offline
Default Re: Antique Steel Wheeled Mechanical Plows...History, Weed Finds, Prices, Parts, Etc.
Okay, went out and grabbed pics of dads plows. A few JD's, an Oliver, and 2 subsoilers. The single bottom JD has the cast Syracuse share on it.
ID:	184325   Click image for larger version
ID:	184326   Click image for larger version
ID:	184327   Click image for larger version
The Following 4 Users Say Thank You to IWL BCNU For This Post:
Old 01-08-2014, 08:06:45 PM
And the rest
ID:	184329   Click image for larger version
The Following 7 Users Say Thank You to IWL BCNU For This Post:
  #43
Old 01-09-2014, 09:46:51 PM
Looks like a pretty stout subsoiler!
Old 01-11-2014, 03:05:14 PM
oldjdinterest oldjdinterest is offline
Originally Posted by oldjdinterest View Post
Hi Tony, great thread you opened! I am also a plow fanatic and has already restored some plows. My latest is a John Deere No-45-C, for behind my GP. Now I am restoring a John Deere No-4 with bottlecap wheel from about 1929. Parts for this aged plows are difficult and hard to find.
Does somebody have a No-4 parts plow for selling parts?
Thanks Gerrit
This is what I got in the mailbox today! Great item! Now I can connect my plow the right way to my tractor.
Gerrit
The Following 2 Users Say Thank You to oldjdinterest For This Post:
  #45
Old 01-11-2014, 04:13:26 PM
Originally Posted by Tony Thompson View Post
Gerrit,
I do not know what model or number that JD plow in post #14 is. I was told it was paired with a late 20s D tractor when new.
Also I am still hoping someone can identify the Oliver plow in post #1.
I understand draft characteristics of tractor drawn antique plows pretty well. I have learned how to set and plow good enough to do nice looking field work. I am not a plow model expert however, and though I recognize the manufacturer names of most plows I do not know model numbers of hardly any of them.
Thanks for all the interest everyone!
Tony
Hi Tony, I had a look in David Wolfe his plowbook, your plow can be a No-6, what are the beam numbers? The rear wheel lift mechanism looks a little different as the one in the book. Is the landwheel cast with spokes? Maybe we can find out when you have the beam numbers.
Thanks Gerrit
---------- Post added at 03:13 PM ---------- Previous post was at 03:03 PM ----------
Originally Posted by Dan thomas View Post
I purchased this plow on the way home from Leseur swap meet last year. I think it will look nice behind the experimental Waterloo boy.the info I have is that it is a number 2 Built from 1914 to 1918?Does anyone have any more info on this plow? Dan
Hi Dan, That is a really old one, beautiful! I looked in the book of David Wolfe, your plow can be a No-2 Pony Engine Gang, three or four bottom. 14 inch only, years build 1914-1916, only the landwheel don't match with the book it has a spoke wheel on the landside. How does your levers looklike? what are the beamnumbers?
Thanks Gerrit
The Following 3 Users Say Thank You to oldjdinterest For This Post:
  #46
Old 01-11-2014, 07:10:18 PM
Dan thomas Dan thomas is offline
Gerrit , the beam numbers are 422,423,424 .I thought that the lift wheel was incorrect for it. I also have a #5 plow that is a late version as the beam stablelizers are flat across instead of the arched ones like the #2 plow ,it has the correct wheel that will also work on the #2 . Dan
The Following 2 Users Say Thank You to Dan thomas For This Post:
  #47
Old 01-11-2014, 10:25:18 PM
i finally got the pics of # 5 plow to load dan
Name:	iphone pics 153.jpg
ID:	184617   Click image for larger version
Name:	iphone pics 154.jpg
The Following 3 Users Say Thank You to Dan thomas For This Post:
  #48
Old 01-12-2014, 06:23:15 AM
Dan, beam numbers can be correct, only beamnumber 424 stands for the fourth beam, the third beam has the number 425, but model number 3 pony Tractor Plow build 1915-1916 has the numbers 422,423,424 and looks almost the same as the number 2.
I think you should also must have the plow book from David Wolfe, you have more plows in the yard i noticed. The book also says the No-3 has two or three bottoms and the No-2 has three or four.
Gerrit
Old 01-14-2014, 02:49:10 PM
53 Super M 53 Super M is offline
Referring to post 44,I have 2 of those clevises,one Dad used for years with the SM and 3-14 Oliver plow has a pretty good size notch wore in it and the other I picked up at an auction in a box of stuff almost mint condition.
Old 01-17-2014, 09:16:24 AM
Nebraska Cowman's Avatar
Nebraska Cowman Nebraska Cowman is offline
I guess I better chime in. I started messing with plows in 1998 after seeing the plowing contests at Madison SD. The first plow I restored was a Case Centennial, 2 x 16 which I finished out in red and green. I'll have to see if I can find a picture of it. Here is one of my fav toys, an IH Whirlwind Terracer plow. It is a lot of fun to use and show and I have built several terraces with it.
My current plows are this pick up 3 x16 Kverneland
Here is another pic of it on my 656. That's grease on the bottoms. I don't let it get rusty.
Here is one I should get working at some point. It is actually a set of JI Case bottoms fitted to a mounted lister frame to fit a Farmall Regular.
The Following 4 Users Say Thank You to Nebraska Cowman For This Post:
Old steel wheeled tractor in a movie model k rumely Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 54 12-30-2016 04:41:01 PM
IHC steel wheeled wagon JHuggans Farm + Industrial Antiques and Collectibles 0 01-19-2013 08:09:04 PM
Another Steel Wheeled H Nebraska Cowman Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 08-12-2012 06:05:17 PM
Steel Wheeled Farmall H daleed Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 7 10-09-2011 08:01:41 PM
Steel wheeled wagon JIMnWV Horse Drawn Equipment 2 09-30-2010 08:09:00 PM
