Smokstak Down Under
First Engine for 2019
this thread has 16 replies and has been viewed 1975 times
Old 01-29-2019, 04:05:38 AM
Wayne Timms Wayne Timms is offline
Default First Engine for 2019
Hi,
I always wanted one of these engines, thanks to some great friends, I am lucky enough to have one. I love the really unusual look of the engine.
The engine is a french Lunant, it will take a little time to get it back together, but I am looking forward to the work and seeing it run.
Regards,
Wayne
ID:	327449   Click image for larger version
Old 01-29-2019, 08:13:18 AM
Tranter Tranter is offline
Default Re: First Engine for 2019
Very nice Wayne!! Looking forward to seeing the engine running ��
The Following User Says Thank You to Tranter For This Post:
Old 01-29-2019, 12:02:34 PM
Anton van der Cruijsen Anton van der Cruijsen is offline
Will you bring it back to Nuenen this year Wayne??
The Following User Says Thank You to Anton van der Cruijsen For This Post:
Old 02-01-2019, 08:27:03 PM
waynocp waynocp is offline
Picked up his crossley oil engine yesterday first one for 2019!
ID:	327720   Click image for larger version
The Following 3 Users Say Thank You to waynocp For This Post:
Old 02-01-2019, 11:01:49 PM
Hi waynocp,
Looks like an electric version?
Regards,
Wayne
Old 02-02-2019, 12:32:50 AM
Hi Wayne
Was told it ran a water pump ,but i am unsure!
Cheers
Old 03-17-2019, 02:28:01 AM
A little bit of an update on the Lunant.
I made a new gudgeon pin using a grade 8 bolt. Got it right the first time so didn't need the spare. The big end studs were a little stretched so have replaced them with high tensile bolts. The originals were 10 mm so I brought some 12mm, machined them and cut the new threads, made new nuts as well as they weren't original.
The main bearing on the flywheel side was past its use by date so made a new one. A few other small jobs on it.
Currently working on building a new hot tube chimney in the 'french style' as I don't know what the original should look like. Still need to sort out the exhaust and the air intake pipe.
The little ball and pipe needs to be on it to run it at the moment, but its not original. The electric motor in the photo was used to start the engine the first few times until I put one of Wayne Grenning's gas bags on it, which sorted out the issues.
Put the tacho on it today and its running a treat at around 100 rpm. I'll post a video of it running when it is complete.
Regards,
Wayne
ID:	330783   Click image for larger version
ID:	330784   Click image for larger version
Old 03-17-2019, 07:14:12 AM
RustyNumbat RustyNumbat is offline
Take a decent video and put it on youtube, the only ones I could find are really low quality from a decade ago. (What is it with interesting and uncommon machines, it ALWAYS seems to be just a single ancient and terrible quality video online?)
The Following User Says Thank You to RustyNumbat For This Post:
Old 05-19-2019, 02:55:40 AM
I have virtually completed all the work on the engine. It has a new hottube chimney, I redesigned the air intake tube.
I designed a new muffler/exhaust box in a style in keeping with the engine.
The door on the base had been damaged and I had been debating leaving it but decided to repair it. I had a casting made of the lug and then fusion welded it back onto the door. I am pretty happy with the way-out turned out, unfortunately the paint was burnt off in the process, but I have been able to match it quite well.
When I get a chance I will get it running and my son will video the engine and load it onto youtube.
Regards,
Wayne
ID:	335110   Click image for larger version
ID:	335111   Click image for larger version
ID:	335112   Click image for larger version
Old 05-25-2019, 12:13:45 AM
Hi,
Thanks to my son and his go-pro we have loaded a video of the engine running on you tube.
https://youtu.be/dn7xRLFKY2w
Regards,
Wayne
The Following 13 Users Say Thank You to Wayne Timms For This Post:
Old 05-25-2019, 12:29:48 AM
jayvee jayvee is offline
Wayne
The link does not work for me. Damn!
jayvee
The Following 2 Users Say Thank You to jayvee For This Post:
Old 05-25-2019, 12:37:59 AM
Hi jayvee,
Thanks for the heads up - no idea how to fix it.
Maybe if you copy and paste it will work for you?
Sorry, Wayne
Old 05-25-2019, 12:52:08 AM
Paul Richardson Paul Richardson is online now
Link working fine here Wayne,subject and vid both operating well.
Only opening the vid on an old iPhone,will try pc later.
The Following User Says Thank You to Paul Richardson For This Post:
Old 05-25-2019, 02:30:23 AM
Mick's Avatar
Mick Mick is offline
Images: 21
Works for me, fantastic engine, runs sweetly and first class resto as always wayne!
The Following User Says Thank You to Mick For This Post:
Old 05-25-2019, 08:00:31 AM
Tim B's Avatar
Tim B Tim B is offline
Very nice job and sweet running too!
Explorer wont open the movie, but google would for me.
The Following User Says Thank You to Tim B For This Post:
Old 05-25-2019, 11:57:10 PM
cobbadog cobbadog is offline
Works for me now for some strange reason.
Very nice to see it running, well done and thanks for sharing.
Old 05-26-2019, 12:58:18 AM
Duey C Duey C is offline
Very very cool engine.
Thank you for the clip!
Mozilla/Pale Moon did it for me no prob.
Too much to add about the gas governor.
The Following 2 Users Say Thank You to Duey C For This Post:
Jacob Haisch Gas Engine Feature for 2019 at Rollag JSWithers Antique Gas Engine Discussion 28 06-22-2019 11:12:04 AM
New Engine Show May 18th 2019 Lima NY Frank DeWitt Shows and Swap Meets 7 05-05-2019 03:27:19 PM
traction engine events in USA 2019 gillijen Smokstak Forums Meet and Greet 10 02-06-2019 04:32:41 PM
2019 Engine Calendar Offering Travis Benner Antique Gas Engine Discussion 12 12-22-2018 04:40:04 PM
2019 Steam Engine Calendar Harry Steam Stationary Engines, Traction Engines 0 11-10-2018 10:54:55 PM
