Go Back   SmokStak > SmokStak® General Discussion > Live Auctions of Engines, Tractors and Old Iron
Live Auctions of Engines, Tractors and Old Iron Live auctions and estate sales of engines, tractors, and old iron machinery. Upcoming auctions and auction results.
Twin City Big Twin Cam up for Sale
this thread has 29 replies and has been viewed 7849 times
Old 11-29-2016, 08:58:44 AM
Jim Anderson's Avatar
Jim Anderson Jim Anderson is offline
Default Re: Twin City Big Twin Cam up for Sale
Originally Posted by ajs2744TC View Post
Kinda would like to find exhaust elbow. I actually need 3. But 2 for sure.
Hi Adam
I needed an exhaust elbow for my 17-28 and one for my 27-44. I ordered 2 1/2 inch and 3 inch elbows from McMaster Carr. Then I found a piece of scrap pipe to make the collars out of. I had to make a cut in the side of the collar to get the right diameter and weld it back together. Then I welded the collars to the elbows and ground the welds smooth. On the 2 1/2 inch elbow I cut 1 1/4 inch off the other end of the elbow and on the 3 inch elbow I cut 1 1/2 inch off the end of the elbow. The set screws and jam nuts came from Menards. The 1st picture is the elbows before fab work. The 2nd picture is the finished elbows. The 3rd picture is installed on the 17-28. The 4th picture is installed on the 27-44.
Name:	new elbows.png
ID:	269105Click image for larger version
Name:	exhaust elbows.png
ID:	269106Click image for larger version
Name:	small elbow.png
ID:	269107Click image for larger version
Name:	large elbow.png
The Following User Says Thank You to Jim Anderson For This Post:
Old 11-29-2016, 08:42:32 PM
Those steel fabricated turnouts came out nice. It's hard to tell that they actually aren't cast iron. What's the wall thickness on those elbows?
The Following User Says Thank You to Mark Schneider For This Post:
  #23
Old 11-30-2016, 12:42:59 AM
Hi Mark
The wall thickness is .203 inches on the small elbow and .216 inches on the large elbow.
Old 11-30-2016, 07:23:04 AM
ajs2744TC ajs2744TC is offline
Not any significant updates. Going to need a few more valves than planned and guides. Currently still cussing at 250116 at the moment. Having troubles locating at least 10 valve springs that don't cost 40$ a piece. Been fixing littles on 146 in preparation for spring when I hope to dig into it.
---------- Post added at 07:23:04 AM ---------- Previous post was at 07:18:39 AM ----------
Nice elbows! I may just go that route unless you made up extras Jim.
Old 11-30-2016, 08:45:48 AM
Thanks for the update. Were you able to find a piston?
I'm currently trying to work through an unexpected problem with the main bearing shells. Closer inspection revealed that they had run loose in the bores for some time and now are slightly undersize on the OD...the front main being the worst.
Pat Bayer has a new set of valve springs listed for sale in classifieds for $12 a pop. Probably never find them cheaper than that.
Old 11-30-2016, 09:37:16 AM
I find the easiest way to post pictures is to take them with my phone, email them to myself in the medium scale. I can then save the pictures and post with no problem.
Old 11-30-2016, 10:17:17 PM
Thanks JC I will try it. I will check the adds Mark. That would be good deal.
---------- Post added at 10:17:17 PM ---------- Previous post was at 10:02:55 PM ----------
Yes mark I found a n.o.s piston from a friend. Traded him out of it fairly reasonable.
Old 03-19-2017, 10:58:08 PM
Well today #146 went into the shop for a mechanical resurrection. Should be easier after doing a couple already but there is always surprises to be had. Try to post pics here and there.
The Following 3 Users Say Thank You to ajs2744TC For This Post:
  #29
Old 02-28-2019, 12:02:57 AM
Yes! Been a while since I've updated this thread. 146 is going back together over past 2 months with a plan to start in late March. Had a hold up with just about every unplanned that could appear and life, work etc. Sometimes the nit picky things consume the most time. Unplanned timing parts repairs and many small items etc. But you all know that song and dance a time or two.
ID:	329616   Click image for larger version
  #30
Old 02-28-2019, 12:04:46 AM
Last pic was originally owner threshing with 146. Hope to get few more.
The Following User Says Thank You to ajs2744TC For This Post:
Twin City 17-28...My Intiation into the Twin Cam Faternity! Mark Schneider Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 120 06-01-2018 09:21:55 AM
Twin City 40 Mike Harmeling Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 184 03-05-2018 10:15:41 AM
Twin City rhawke Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 24 11-15-2015 01:14:51 AM
Twin City at Lathrop Missouri sale KevinR Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 11 05-25-2015 10:35:16 PM
Twin City 20-35 & 27-44 for sale Tony Thompson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 05-25-2011 01:35:35 PM
