Go Back   SmokStak > SmokStak® General Discussion > Live Auctions of Engines, Tractors and Old Iron
Live Auctions of Engines, Tractors and Old Iron Live auctions and estate sales of engines, tractors, and old iron machinery. Upcoming auctions and auction results.
U6501 Continental 6 cylider gas engine
this thread has 15 replies and has been viewed 3838 times
Old 02-08-2017, 05:36:17 PM
Default Re: U6501 Continental 6 cylider gas engine
I am used to the Continental D & F series engines which use the same bearing set. They both use the front main to control thrust. The shim pack is used to set the crankshaft end play to the correct amount. I will not look up any bearing sets, but FYI for you I know insert bearings have also been reoured.
Old 02-08-2017, 11:16:24 PM
rdrodgers rdrodgers is offline
Thanks, I have looked into having the old set repoured, but one main bearing spun and the block had to be line bored, and one rod bearing shell is beyond repair as well as the main bearing shell that spun.
I do have a lead on a set and hoping to know in a few more days.
Thanks again for the help and suggestions.
Old 02-09-2017, 01:23:00 AM
keith1944 keith1944 is offline
Douglas County Fire District #2 in Roseburg Oregon has a 1940 Holabird pumper parade unit. It was originally owned by Veterans Administration Medical Center, Roseburg. I can put you in touch with their mechanic if you want.
Old 02-09-2017, 09:50:23 AM
Yes please. The more information I can get from someone who has worked on one the better off I will be. Thank you. Should I private message you my contact information?
Old 03-08-2017, 03:15:14 PM
Parts did not pan out. No rod bearings available, but did have another engine donated so I can get the rod bearings from it.
I'm sure the bearing shells will need to be redone. Anyone know where would be a good place to send bearing shells to have new babbitt or bearing material put on?
Thanks again
Old 11-04-2018, 02:23:43 PM
Curtis Elliott Curtis Elliott is offline
You stated you may have had a spare U501 Continental engine donated for a fire truck. I would be interested in buying this engine or any parts if you are interested. My email is Ctobac1@yahoo.com.
Thank you for your time.
Value Of A Continental Y-69 Engine Rod Krehbiel Antique Farm Tractors 10 04-07-2018 07:33:43 PM
continental engine?? enginecrzy Small Air Cooled Gasoline Engines 2 09-20-2016 07:43:36 AM
Need help with Continental engine...Please! firetrucksaver Antique Autos and Trucks 2 08-22-2011 10:05:37 AM
In Need of Continental 6B engine 1939 Fox Antique Gas Engine Discussion 2 08-18-2011 07:24:40 AM
85 hp Continental Gin Engine FarmSC Vintage Diesel and Oil Engines 1 09-29-2008 10:25:10 PM
