Smokstak Down Under
Test Photo Uploading
this thread has 6 replies and has been viewed 3250 times
Old 03-02-2018, 11:39:04 AM
Harry's Avatar
Images: 316
Default Test Photo Uploading
This is a test of iPhone 10 uploads. Working on iPhone procedures.
Edit: IT'S HOW YOU HOLD YOUR CAMERA! The darn Apple remembers the position.
https://www.smokstak.com/forum/showp...1&postcount=28
#1 is from iPhone direct. #2 is emailed to iPhone from the above edited post.
Work continues. These photos are from prints taken with a Canon 35mm film camera and copied with an iPhone 10.
It's all in the camera orientation, specifically from an iPhone.
ID:	305117   Click image for larger version
The Following User Says Thank You to Harry For This Post:
Old 03-03-2018, 03:08:38 AM
Harry's Avatar
Images: 316
Default Re: Test Photo Uploading
https://www.smokstak.com/forum/showthread.php?t=168201
https://www.smokstak.com/forum/showthread.php?t=176004
https://www.smokstak.com/forum/showp...21&postcount=6
https://www.smokstak.com/forum/showp...28&postcount=7
Old 03-08-2018, 12:43:40 AM
Harry's Avatar
Images: 316
Adding two photos simultaneously from iPhone 10.
ID:	305119   Click image for larger version
Old 03-09-2018, 11:27:59 AM
Harry's Avatar
Images: 316
Testing again with phone upright and sideways.
This appears to be an iPhone problem!
Upright is on the left and horizontal is on the right.
Note that upright takes in three panels and horizontal takes in four panels.
ID:	305121   Click image for larger version
Old 03-09-2018, 11:58:41 AM
Harry's Avatar
Images: 316
This is the same test with the server set to GD instead of ImageMagick.
No difference, they both work the same.
ID:	305123   Click image for larger version
Old 03-09-2018, 12:04:45 PM
Harry's Avatar
Images: 316
So, holding the phone horizontally with the volume buttons down comes through fine.
It's the vertical that's causing the problems, just like the sides being cut off on videos.
The iPhone EXIF data attachment carries the camera position information for any photo.
Google: iphone pictures sideways
Basically, you should take videos and photos with the volume up/down buttons on the bottom of your phone. Try telling that to the world. An iPhone can take amazing videos, so why lose 2/3 of the screen capacity?
Old 03-09-2018, 12:21:37 PM
Harry's Avatar
Images: 316
Down is up and up is down.
Photo one: volume buttons down.
Photo two: volume buttons up.
Damned if uploading doesn't rotate the image!
The purpose of using GD or ImageMagick is to automatically reduce the Image Size to 1024 X 768 and compress your 4MB photos down to 100k to 200k. Without doing this, your photos would be way off the edge of your screen. Not acceptable.
Your phone remembers your camera position and places that information in an EXIF file attachment to your photo.
ID:	305125   Click image for larger version
Photo Uploading Sideways & Upside Down PaulGray Computer, Camera and ISP Problems 13 03-16-2018 06:21:01 AM
Photo Uploading Problems Harry Computer, Camera and ISP Problems 1 02-13-2018 04:02:22 AM
Photo Uploading Problems Harry How to use this web site: 0 02-10-2018 09:57:14 AM
uploading photo Dan Wiese Antique Gas Engine Discussion 1 10-17-2006 08:42:34 PM
Uploading Photo Attachments Harry Antique Gas Engine Discussion 0 09-30-2006 10:25:13 PM
