Smokstak Down Under
Tangyes: Searched 30 Years 1895 Tangyes 2HP Petroleum Engine
this thread has 12 replies and has been viewed 2068 times
Old 11-20-2018, 02:47:08 AM
Bug1929 Bug1929 is offline
Photo Tangyes: Searched 30 Years 1895 Tangyes 2HP Petroleum Engine
Hi I've been searching for 30 years to get an engine built pre-1900. At last I found one in New Zealand. It's a 1895 Tangyes 2 HP Petroleum Engine Serial Number: 787. The Serial Number stamped under the Brass Plate is: 1317. It was found at an old Saw Mill site back in the 1950's north of Auckland. Partly buried with the hot bulb sticking out of the ground. The bronze Hot Bulb was missing and a few other parts too. I bought it fully Restored. It was from a private collection of 50 odd engines and this was the favourite engine of the collection. I'll post some more photo's of it later on. Regards from Geoff.
Name:	1895 Tangyes 2 HP Petroleum Engine Serial No 787 Number under Brass Plate is 1317 Restored A.jpg
ID:	323214   Click image for larger version
Name:	1895 Tangyes 2 HP Petroleum Engine Serial No 787 Number under Brass Plate is 1317 Restored F.jpg
Old 11-20-2018, 10:40:36 AM
Default Re: Tangyes: Searched 30 Years 1895 Tangyes 2HP Petroleum Engine
More photo's as promised. Regards from Geoff.
Name:	1895 Tangyes 2 HP Petroleum Engine Serial No 787 Number under Brass Plate is 1317 Restored C.jpg
ID:	323225   Click image for larger version
Name:	1895 Tangyes 2 HP Petroleum Engine Serial No 787 Number under Brass Plate is 1317 Restored D.jpg
ID:	323226   Click image for larger version
Name:	1895 Tangyes 2 HP Petroleum Engine Serial No 787 Number under Brass Plate is 1317 Restored G.jpg
ID:	323227   Click image for larger version
Name:	1895 Tangyes 2 HP Petroleum Engine Serial No 787 Number under Brass Plate is 1317 Restored H.jpg
The Following 5 Users Say Thank You to Bug1929 For This Post:
Old 11-20-2018, 10:48:19 AM
3rd set of photo's as promised. Regards from Geoff.
Name:	1895 Tangyes 2 HP Petroleum Engine Serial No 787 Number under Brass Plate is 1317 Restored I.jpg
ID:	323233   Click image for larger version
Name:	1895 Tangyes 2 HP Petroleum Engine Serial No 787 Number under Brass Plate is 1317 Restored J.jpg
ID:	323234   Click image for larger version
Name:	1895 Tangyes 2 HP Petroleum Engine Serial No 787 Number under Brass Plate is 1317 Restored K.jpg
ID:	323235   Click image for larger version
Name:	1895 Tangyes 2 HP Petroleum Engine Serial No 787 Number under Brass Plate is 1317 Restored L.jpg
The Following 4 Users Say Thank You to Bug1929 For This Post:
Old 11-20-2018, 10:51:09 AM
4th set of photo's, as promised. Regards from Geoff.
Name:	1895 Tangyes 2 HP Petroleum Engine Serial No 787 Number under Brass Plate is 1317 Restored M.jpg
ID:	323237   Click image for larger version
Name:	1895 Tangyes 2 HP Petroleum Engine Serial No 787 Number under Brass Plate is 1317 Restored N.jpg
ID:	323238   Click image for larger version
Name:	1895 Tangyes 2 HP Petroleum Engine Serial No 787 Number under Brass Plate is 1317 Restored O.jpg
ID:	323239   Click image for larger version
Name:	1895 Tangyes 2 HP Petroleum Engine Serial No 787 Number under Brass Plate is 1317 Restored P.jpg
Old 11-20-2018, 10:57:33 AM
Photo Re: Tangyes: Searched 30 Years 1895 Tangyes 2HP Petroleum Engine
5th and final set of photo's, as promised. Regards from Geoff.
Name:	1895 Tangyes 2 HP Petroleum Engine Serial No 787 Number under Brass Plate is 1317 Restored B.jpg
ID:	323241   Click image for larger version
Name:	1895 Tangyes 2 HP Petroleum Engine Serial No 787 Number under Brass Plate is 1317 Restored Q.jpg
ID:	323242   Click image for larger version
Name:	1895 Tangyes 2 HP Petroleum Engine Serial No 787 Number under Brass Plate is 1317 Restored S.jpg
ID:	323243   Click image for larger version
The Following 11 Users Say Thank You to Bug1929 For This Post:
Old 11-20-2018, 01:47:18 PM
Tim Macaire Tim Macaire is offline
Hi Geoff,
Very nice engine, Tangyes Petroleum engines are one of my favourite. I remember seeing this engine about 10 years ago, It seemed quite a big engine at the time, bigger than 2hp I thought but maybe my memory is not what it used to be. I am wondering if you could check the number on the block for me, I have it as 787 on the brass tag and 4121 on the block?
Cheers. Tim
The Following 2 Users Say Thank You to Tim Macaire For This Post:
Old 11-21-2018, 01:38:01 AM
cobbadog cobbadog is offline
How big is your smile at the moment Geoff?
You must be so pleased that after 30 years of searching you have what you wanted.
What is the next one you want?
Old 11-22-2018, 01:22:00 AM
Hi Tim, it's Serial Number: 787 on the brass plate and Serial Number: 1317 stamped into the block. You can see it on the 3rd set of photo's and the last photo Tim. Regards from Geoff.
---------- Post added at 06:22:00 PM ---------- Previous post was at 06:04:17 PM ----------
Hi Cobbadog, I don't want anymore engines. I've got the Tangyes Petroleum engine, a 1912 Mason and Porter Made in Auckland, New Zealand by City Engineering Serial Number: 24. My first engine that started me collecting, a 1928 Lister "D" Petrol Engine, with a direct drive magneto. And I've got a 1956 Lister FR6 Diesel Engine driving a 40 KVA generator, Serial Number: 150FR6R6. But I have first rights on a 1903 Campbell 6HP Girder Portable Continuous Blowlamp Engine, it's a 1 family owned engine from brand new, which I would keep too. Regards from Geoff.
The Following 2 Users Say Thank You to Bug1929 For This Post:
Old 11-22-2018, 03:39:14 AM
Wayne Timms Wayne Timms is offline
Hi Geoff,
Congratulations on the Tangye - definitely a very early engine!
I have to agree with Tim, the gas number seems to be too far out of sequence with other surviving engines. I can't be sure, but from you photo, the number looks like the number Tim is quoting.
A 4000 gas number sounds right for a 700 oil engine. (roughly)
Regards,
Wayne
Old 11-22-2018, 04:59:14 PM
Kerry Morris Kerry Morris is offline
G'Day Wayne, From the register i run there are 11 Tangyes with the two numbers, checking these more closely in what the difference between the two numbers are, Geoff's is the earliest and has a difference of 530, I have one at 863 difference, three in the 2000's different, one in the 4000's different, five in the 6000's difference and one in the 8000's difference which is the last I have with two numbers, from what the register shows is that except for one engine as the numbers increased so did the difference, assume Tangye was selling more Gas engines so that series of numbers increased more quickly
All the best
Kerry
The Following 3 Users Say Thank You to Kerry Morris For This Post:
Old 11-22-2018, 06:09:20 PM
Hi Kerry, Wayne, Geoff,
From my list I have two numbers very close to Geoff's, one slightly earlier but still in the 700's which has a late #3000 number and one in the early 900's which has a mid #4000 number which is why I thought Geoff's number should be around 4000 as Wayne suggested. Tangyes must be laughing their heads off with all the conversations and confusions they have caused with their dating and engine numbers!
Tim
The Following 3 Users Say Thank You to Tim Macaire For This Post:
Old 01-05-2019, 09:40:35 AM
Hi Tim and everybody else, next time I'm at my storage shed I'll take the paint off the block under the Number 787 Brass Plate to see if it's a different number stamped into the block. Then take another photo to confirm the number, so there is no mistake. Regards from Geoff.
The Following 3 Users Say Thank You to Bug1929 For This Post:
Old 03-13-2019, 01:23:14 AM
I have picked up my 1895 Tangyes 2 HP Petroleum Engine from storage 2 weeks ago. I have chiselled off the paint under the brass oval badge too. To my surprise I found Number: 4121, so Tim is right. I'm sorry I got it wrong. I rallied the engine last Sunday for the first time. It's a beautiful running engine. I've fitted 2 LPG torches to run the engine. I've had to make a steel Hot Bulb Cover. Because the wind kept blowing out the torches last Wednesday. The engine drew a lot of people, some kept coming back. I've got another show this coming Saturday too. In the future I'll get the right Hot Bulb, Fuel Tank, the 2 Burners and Fuel Tank and Big End Bearing made. Also I'm looking at mounting it on a trolley. Once it's been placed on the ground with my crane truck, it can't be moved. Regards from Geoff.
ID:	330538   Click image for larger version
ID:	330539   Click image for larger version
ID:	330540   Click image for larger version
Tangyes Bubsengine Smokstak Down Under 6 10-03-2016 02:49:33 AM
4 HP Tangyes Gas Engine Bill Hazzard Antique Gas Engine Discussion 45 01-15-2016 07:50:56 PM
Tangyes Engine Trevor A Cole Antique Gas Engine Discussion 8 12-26-2015 06:52:14 PM
1899 or 1900 Tangyes Gas Engine 2422 Bug1929 Smokstak Down Under 10 01-21-2013 06:48:37 AM
Petter, Tangyes video Mozart.1756 YouTube Old Iron Videos 2 01-28-2010 10:23:12 AM
