Smokstak Down Under
Old self propelled mower. Atco?
this thread has 14 replies and has been viewed 1037 times
Old 01-27-2019, 01:50:56 AM
AussieIron AussieIron is offline
Default Old self propelled mower. Atco?
Got this mower cheap yesterday.I knowit's not that old, probably 1950's would pull it up. No carby or fuel line and throttle cable. Carby inlet on motor is appox 20mm. Just wondering what is correct make, and carby throttle set up? Cheers Neil.
ID:	327244   Click image for larger version
ID:	327245   Click image for larger version
ID:	327246   Click image for larger version
The Following User Says Thank You to AussieIron For This Post:
Old 01-27-2019, 04:54:18 AM
klanger57 klanger57 is offline
Default Re: Old self propelled mower. Atco?
I would think a villiers of some description would work.
The Following User Says Thank You to klanger57 For This Post:
Old 01-27-2019, 06:01:43 AM
rodneyt rodneyt is offline
its got an 'ATCO' look to it,
sure 'nuf:
https://duckduckgo.com/?q=atco+ville...er&t=hp&ia=web
ooooo... even a thread here...
https://www.smokstak.com/forum/showthread.php?t=181047
cheers Rod.
The Following 2 Users Say Thank You to rodneyt For This Post:
Old 01-27-2019, 10:12:54 PM
cobbadog cobbadog is offline
At aguess it is a Mk1 which uses the standard Villiers carby, cable and hand throttle and readily available evrywhere from rallies to fleabay. Just about all Villiers 2 stroke mower engines used the same carby. It will have a date stamped on the brass flywheel which should be month/year. Great mowers and still popular. I have a Ransomes Simms & Jefferies which has what looks like the same engine.
Old 01-27-2019, 11:17:18 PM
Thanks, Couldn't see any numbers on flywheel.Still seems to have spark so worth a go to get it going. Freed up the dog clutch. Seen some pictures of the carby and I had one of those kicking around for ages and gave it away! Will look for one at Ballarat swap. Thanks for help, Cheers Neil.
Old 01-28-2019, 12:51:01 AM
G'Day Neil. No doubt you will find everything at the swap meet. Numbers are stamped on or near the spokes of the flywheel. Sometmes they need a bit of fine wet n dry to enhance them and other times they are so bold you cant miss them. The flywheel should have had an aluminium cover to keep the dust out and the numbers will be there so look carefully. They are usually about 1/4" tall.
The original hand throttle is just like the victa one but is a round lever usually with a ball on the end. There were a few different styles of air filter, from a bell shaped inlet with a metal gauze to a metal canister style. Look around they will be out there and should not be expensive at all. To get an idea on value of the carby do the fleabay thing they turn up there a bit but around $20.00 should get near the lot depending on condition.
Just looked on fleabay and what you want complete from throttle lever to air filter is listed for $25.00
+ postage from Newcastle NSW. Have a look so you know what to look for at the swap meet then if not successful by one off the net. Hope this helps
Old 01-28-2019, 03:52:10 AM
Thanks,I'll look now, thanks for your help-Cheers-Neil.
---------- Post added at 02:52:10 AM ---------- Previous post was at 02:03:08 AM ----------
What's the description of the one on Ebay please Cobba, can't seem to find it.-Thanks
Old 01-28-2019, 10:53:23 PM
I jst opened fleabay and typed in villiers carby and 2 came up straight away.
John
Old 01-29-2019, 12:06:54 AM
Just did the same and there they are, buggered if I know what happened yesterday. Thanks.
Old 01-29-2019, 12:23:09 AM
Rusty Engines Rusty Engines is offline
eMail NOT Working
This is what John is talking about, there is some different versions
Ian
The brass one 6-56, 6 month year 1956
ID:	327419   Click image for larger version
ID:	327420   Click image for larger version
The Following 2 Users Say Thank You to Rusty Engines For This Post:
Old 02-11-2019, 01:33:22 AM
Hi Neil,
Did you find the carby and throttle lever yet good enough to buy?
Old 02-12-2019, 12:26:06 AM
ulgydog56's Avatar
cool, what a crazy little lawn mower....
The Following User Says Thank You to ulgydog56 For This Post:
Old 02-23-2019, 05:48:53 PM
Went to Ballarat Swap Friday. Saw a complete atco, pricey, but good unit. Mine is ok so all I need is carb and throttle. Saw a few carbs but not good nick. Will get one now at least I know what I want thanks to you blokes. Swap meets are changing, heaps of crap for sale with a few gems in between. Then again, I'm much more choosey now, only buy what I "specialize" in I guess. They even had an amusement park in the centre of the swap, dodgem cars and all. Guess that's ok for bored kids but seems anything to make more $ is the go. Bloody electric and motorized scooters and bikes everywhere with young fit blokes on them, I don't get that. If you're crook that's ok, but just lazy? While I was lined up to get in, I counted about 150 people in front, same behind me. At $15 a head, comming in all day, plus site fees,not a bad days work for someone? Will take cover off flywheel and see date, have mower at home today. Enough whingeing, cheers- Neil
Old 02-24-2019, 06:25:13 PM
Cobbadog, Numbers on flywheel under cover are- R 52 A52M 3 / 8. so I'm guessing 1952.
Will get a carb, a good one will turn up. Thanks to all again.-- Neil.
Old 02-25-2019, 12:31:43 AM
Yep 1952. Any carby will clean up perfectly well and work. the difference is the condition of the cable. throttle levers are still fairly common too. So keep an eye out in those mower parts section of the auction sites.
I had some very ugly looking carbies for a Model 1 Victa and hit it up in the bead blaster, came out like brand new.
Atco Villiers Engine on Mower Weldspec Small Air Cooled Gasoline Engines 7 09-22-2018 07:03:18 PM
Barn Fresh Atco 14 inch Mower James Bosma Garden Tractors / Mowers / Scooters 6 02-20-2013 12:39:22 AM
1920's self propelled automatic mower imotorhead64 Garden Tractors / Mowers / Scooters 4 02-08-2013 11:26:19 AM
Atco Mower with Villiers Engine Cactus Mutt Garden Tractors / Mowers / Scooters 0 10-21-2009 09:37:47 AM
J.A.P. engine on ATCO mower 4 stroke Philip Plotkin Garden Tractors / Mowers / Scooters 2 07-24-2009 09:29:04 PM
