Smokstak Down Under
Rookie with IHC M
this thread has 34 replies and has been viewed 2718 times
Old 02-09-2019, 07:07:05 PM
john gilbert john gilbert is offline
Default Re: Rookie with IHC M
Hi Guys, another easy way to tell the HP of the "M" is the centres of the fuel tank mounting bolt holes underneath.
They are 1+1/2hp engine:- 14+1/2 inches
3hp engine 16+1/2 inches
6hp engine 23 inches.
I do not have the 10hp, as that is the only one I have never had an order for.
Talking of the 3hp engine, I have just completed another fuel tank for someone who rang me with the order around Christmas time. Yes, I have lost my note and have no idea who it is for ???? getting old is a bummer. Did you order this tank??
Cheers, John
Old 02-10-2019, 01:25:26 AM
Dobbo56 Dobbo56 is offline
John
Wasn't me haven't even look at the fuel tank on my engine yet but its on the list
Cheers Dobbo56
Old 02-10-2019, 10:58:42 PM
Chester Chester is offline
Originally Posted by rodneyt View Post
cheers Rod.
ps can somebody tell me what make is the big flywheel tractor, side views only?
https://www.cockymart.com.au/clearin...g_Sale-776.pdf
Hi Rodney,
Mcdonald.
The Following User Says Thank You to Chester For This Post:
  #24
Old 02-15-2019, 09:13:01 PM
Hi Guys I just had a look at that auction site, mentioned in the last quote and all I can say is "WOW" now I wish I was a bit closer to it as it would be an eye opener to see. Plenty of old engines, tractors etc and tools. Also heaps for the scrappy. Cheers, John
Old 02-18-2019, 03:23:41 AM
Hi Guys
Does anyone know what size the thread is on the oiler tube where it screws into the cylinder ?
The other end where the oiler screws on is 3/8" bsp.
Cheers Dobbo56
Old 02-22-2019, 10:05:23 AM
rodneyt rodneyt is offline
here we go, here we go, here we go,
now is when you start the never ending accumulation of 'just one more' of those seemingly
ordinary tools you never thought you would ever need.
and possibly don't even yet know exist!
and might never need again,
in this case, a thread gauge set.
oops, make that 'sets'...
Old 02-22-2019, 10:00:51 PM
eddie bedwell eddie bedwell is offline
Hi Team,
being a American engine it should/will have NPT (National Pipe) threads for the taper pipe fittings.
Chart below may help.
I guess looking at Shopdog Sam's video of fitting a cylinder liner to an M engine that the lubricator pipe is 1/8" NPT--if not, 1/4" NPT
I spent some $$$'s years ago and bought a set of Thread Files and I am sure the scraping internal thread ends would fit in the 1/8" NPT thread hole--- approx. 3/8 " diameter to allow cleaning up the internal threads.
https://www.plumbingsupply.com/pipethreadsizing.html
https://www.valvesonline.com.au/references/threads/
The Following User Says Thank You to eddie bedwell For This Post:
  #28
Old 02-22-2019, 10:46:47 PM
isandian isandian is offline
Originally Posted by Chester View Post
Hi Rodney,
Mcdonald.
I confirm it is a McDonald TWB of the mid to late 30's. Pretty complete example.
ian
The Following User Says Thank You to isandian For This Post:
  #29
Old 03-08-2019, 08:03:12 AM
Have pulled the carby down and what a mess!
2 springs missing on neddle valves, both syphon tubes corroded and broken, see pics
ID:	330173   Click image for larger version
Old 03-24-2019, 10:42:48 AM
perthlisterfan perthlisterfan is offline
Went to the Goomalling sale yesterday. Was a good day and well attended. Over 400 lots that were sold over about 6 hours. Small stuff sold very well, and larger stuff sold cheaper. The Crossley sold for $18,000. The Gray on the transport sold for $1400. The New Way CH sold for $600. I was happy as I picked up the Denbigh drill for $250 and the IHC “M” series and big lister fuel tank for $700. Also picked up a complete oxy kit with bottles and about 50 spare cutting tips for $60.
Old 04-07-2019, 10:32:20 PM
Angry Re: Rookie with IHC M
Hi guys have been doing a little work on the M.
Removed the fuel tank to check it for leaks none found . HOWEVER I have discovered a hole in the casting see picture, anyone had done any repairs on case?
Old 04-08-2019, 12:46:32 AM
Jonesey Jonesey is offline
Iíve had good success repairing cast iron casings with an epoxy putty that is sold at Repco stores, it comes in a stick that you cut off a piece which has 2 layers that you knead together until the colour is consistent. Press into gap or crack and it sets in 4 minutes. Itís brand name is Dynasteel Epoxy Putty and JB Weld also market a similar product.
Getting back to your Oiler thread, on my M itís 1/4Ē NPT, the Brass tube can be purchased from Hit N Miss Enterprises in the US. Good Luck Les
Old 04-08-2019, 01:53:42 AM
cobbadog cobbadog is offline
Selleys also make an epoxy putty named "U-need-It" and you can find it at Bunnings. I have used it in a few jobs and it can be drilled and tapped once hardened correctly in a day or so.
  #34
Old 04-08-2019, 06:28:15 AM
Jonesey
Thanks for the info on the putty.
Ihave purchased an oil tube from Cam (Mtype) plus a few other items he had
Cheers Dobbo56
---------- Post added at 05:28:15 AM ---------- Previous post was at 05:23:48 AM ----------
Cobbadog
Thanks for the infomation I have used u need it before but didn't think of it to repair cast steel
Cheers
Dobbo56
Old 04-08-2019, 06:52:53 AM
Hi all have stumbled on a virtual gold mine of engines through an old mate have a look at the photos of what is is sitting around, and the owner has had a stroke and will not be able to do anything with them. Hope to get a couple of M's out of it.
Cheers Dobbo56
Fairbanks Morse Owner Rookie Questions oldryder1973 Antique Gas Engine Discussion 6 05-18-2018 05:09:43 PM
Hart Parr questions from a rookie Camerons Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 11-16-2008 10:49:51 AM
4.0 CCK Rookie mistake DAP Onan Generators 6 08-08-2008 08:24:11 AM
Rookie User Needs Help With Onan Delbert Wise Onan Generators 6 06-21-2008 08:16:40 AM
