Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Railroads and Equipment > Railroadiana
Railroadiana Collectibles from the Railroads. Railroadiana or railwayana refers to artifacts of currently or formerly operating railways around the world.
Railroadiana
Railroad track level?
this thread has 10 replies and has been viewed 3099 times
Old 11-11-2017, 09:33:23 AM
LCJudge LCJudge is offline
Default Re: Railroad track level?
Originally Posted by dkamp View Post
In my classes on wheel/rail interface, one of the first things I challenged my students with (experienced railcar maintenance people) was "Can anyone tell me where the STEERING WHEEL is on this train?"
They'd all laugh.
I'd repeat it.
They'd kinda chuckle.
I'd repeat it again...
They'd look at me like I was nuts.
EVERY WHEEL is a steering wheel.
--What??--
What keeps the wheels on the track?
Uh... the flange..
NO. The wheel's profile. It's tapered.
Then I'd put a dixie cup on the table, give it a push, and it'd roll in a circle.
That's what railroad wheels do. One dixie cup on each end of a pencil, and two rails on the table- as long as the wheels are centererd... meaning, each rail rolled on each dixie cup at the SAME DIAMETER POINT, it'd go straight.
Start it off with it being higher on one side than the other, it'll FIND center... because the smaller diameter would not WANT to travel as far as the larger, the wheelset STEERS itself to center.
In a curve, the tracklayer must start the inside arc of a curve BEFORE the outside, so that it draws the inner wheel to smaller diameter of the wheel profile. This causes the axle... and every axle AFTER it... to 'steer' in an arc.
This is why there's stepped notches on that level- it's not to find level, it's to cause a correct arc in a curve.
There's a matching wheel profile gauge... so that the taper of the wheel matches the geometry that level creates.
I know absolutely nothing about the rails / wheel profiles, etc. even though I serve on the Ky Railway Museuem Board of Directors.
Thanks, you've taught me a few basics that helps me understand all this better.
Tommy Turner
The Following User Says Thank You to LCJudge For This Post:
1923 Avery Track Runner Half Track Ed Bezanson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 19 11-06-2017 12:59:33 PM
Is it a Wheel or is it a Track ? OTTO-Sawyer Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 12-02-2016 04:15:13 PM
Track Adjustment IH T6 51T6 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 02-14-2012 11:24:49 PM
Trying to Track Down a 20-40 Rumely dpalser Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 13 12-29-2011 02:24:36 PM
8 or 9 hp Austral trying to track it down Siz Smokstak Down Under 0 04-08-2010 01:37:54 AM
