Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Railroads and Equipment > Railroadiana
Railroadiana Collectibles from the Railroads. Railroadiana or railwayana refers to artifacts of currently or formerly operating railways around the world.
Railroadiana
Adlake Kerosene Switch Signal
this thread has 2 replies and has been viewed 834 times
Old 04-29-2011, 02:50:29 PM
Harry's Avatar
Images: 312
Default Adlake Kerosene Switch Signal
Picked this up at an old antique shop in Oronoco, Minnesota. I love those old shops where you can crawl through the crap and pick up treasures. If you can't smell last winter's mouse pee, you aren't in a good shop. You wouldn't think that there would be enough light from a kerosene lamp to see it on time and I can't imagine depending upon a kerosene lamp to keep a freight train on the right track.
The Following User Says Thank You to Harry For This Post:
Old 11-11-2017, 11:19:35 PM
Pete Deets Pete Deets is offline
Default Re: Adlake Kerosene Switch Signal
Nice find, Harry! Is it stamped for any railroad? The Fresnel lens in each target is quite efficient at focusing the light. At some of the special event weekends at the Mid-Continent Railroad Museum in North Freedom, WI. we will fill and light the switch stand lamps. They are surprisingly easy to spot even with street lights showing or in twilight. Enjoy!......PD
The Following 2 Users Say Thank You to Pete Deets For This Post:
Old 11-12-2017, 10:58:04 AM
John C. Neagley John C. Neagley is offline
In the late 60's when the C&O and B&O merged, I was working on the C&O as a Conducor/Brakeman. The B&O were still using kerosene switch lamps in their yards. At night you could look far down the lead at the color of the switch lamps and clearly see the lineup on the lead. These lamps were much brighter than you could imagine due to the design of the lenses. On cold winter nights, while working the lead aligning switches to direct the next cut of cars coming at me down the lead, I would turn up the flame on the switch lamp nearest me and place one of my gloves at a time on top to warm them up a little. If I had the choice, I would pull pins while switching to be able to run and keep warmer. Working the lead aligning switches then standing still waiting for the cars to pass by, was the very cold end of yard switching on a cold winter's night.
As an afterthought, I'll bet the lamp tender that cleaned and serviced the switchlamps every day cussed the unknown brakeman for sooting up his lamps.
The Following 2 Users Say Thank You to John C. Neagley For This Post:
A pair of ADLAKE forks lamps Tore Blom Antique Autos and Trucks 11 06-05-2017 11:59:24 AM
BGA wiring questions, remote switch wires identification, bad rocker switch? shadow44 Onan Generators 5 06-30-2015 02:14:58 PM
Onan MDJF stops released start switch Centrifugal Switch Problem Chuck711 Onan Generators 10 01-29-2015 03:22:11 PM
Emergency stop switch kicks out when i push start switch hurdy Onan Generators 9 08-29-2012 07:50:51 AM
Signal Corp PE-108 E Leland Generators & Electric Motors General Discussion 4 02-11-2007 10:06:38 AM
