Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Railroads and Equipment > Railroadiana
Railroadiana Collectibles from the Railroads. Railroadiana or railwayana refers to artifacts of currently or formerly operating railways around the world.
Railroadiana
Railroad Coal Stove
this thread has 21 replies and has been viewed 6715 times
Old 04-04-2007, 10:05:29 PM
HBurk HBurk is offline
Default Re: OT, Railroad Coal Stove
Brooder stoves aren't very big, but you can't tuck one of them under your arm. Not the ones we used around here, anyway.
Old 04-04-2007, 10:18:53 PM
Email NOT Working
H.B. Not EVERYTHING is bigger in Texas. They needed eentsy little brooder stoves for their miniature chickens. Kevin
Old 04-04-2007, 11:24:32 PM
John C. Neagley John C. Neagley is offline
Notice the lip right below the top half of your stove. What the stove was used for was to heat ironing flatirons[ often called SADIRONS] placed on the flats above your stove's centerline. The lip holds the irons in place for heating. Not really railroad unless used to iron the wrinkles out of passengers shirts overnight.
Old 04-05-2007, 07:43:01 AM
Rob Leonard's Avatar
Rob Leonard Rob Leonard is offline
I would say that is for a Ice Shanty, I have one about the same size, differant style but it screws to the floor so it wont roll around inside when you are moving your shanty. Rob.
Old 04-05-2007, 08:27:01 AM
MCanady's Avatar
MCanady MCanady is offline
Images: 39
Too bad the stove can't talk. Interesting item to have in your collection
Old 04-05-2007, 09:01:53 AM
Ackman's Avatar
Ackman Ackman is offline
Images: 22
I collect, old Ice Shanty heaters/stoves, for when I get too old to handle the old engines. If that was for an Ice Shanty, it would have to a be fairly good size shanty & some of them are! The ones I have (13), put out some pretty good warmth, for thier size. Neat little stove,though!!!
Old 04-05-2007, 09:26:12 AM
MCanady's Avatar
Images: 39
At my Grandmother's home there used to be a laundry house as an outbuilding and there was a small flat top stove in that building. Like in an earlier post the flat top used to keep Flatirons hot to iron cloth with.
Old 04-05-2007, 09:31:05 AM
MCanady's Avatar
Images: 39
I just viewed the photo of the stove again and I think the bottom plate was bolted to a base with legs.
Old 04-05-2007, 03:14:53 PM
I am in agreement with Paul. It is a tailors stove which was of coarse used in a tailor shop. By keeping several stoves hot and ready for use. Tailors used irons of different shapes rather than the sole plate shape of the common flat iron. I once saw a collection of sad irons and there were several different kinds as well as a stove in the collection with all the flat sides. Joe Morris
Old 04-06-2007, 07:25:45 AM
A little correction is in order. shold read several irons hot instead of several stoves hot. joe Morris
Engine stove Gene Fisher Antique Gas Engine Discussion 20 01-22-2015 12:37:25 AM
Can you still by anthracite coal (hard coal) in Iowa? bentonbee Steam Stationary Engines, Traction Engines, Steam Boats 3 02-19-2013 09:44:32 AM
stove 1.5 k Tim rostar Antique Engine Archives 4 08-23-2004 08:51:41 AM
