Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Kohler Generators
Kohler Generators
Kohler Model 1A21 Light Plant Plug Wire Size
this thread has 2 replies and has been viewed 1883 times
Old 12-27-2012, 05:10:17 PM
TJ marnich TJ marnich is offline
Default Kohler Model 1A21 Light Plant Plug Wire Size
Hi There!
I have a kohler 1A21 light plant I'm restoring right now. Does anyone out there have a suggestion as to what kind of spark plug wire would be acceptable to use with a Bosch MJC4C magneto. I believe a read an article that said that the newer automotive wire was not a good replacement. Any help on this matter would be greatly appreciated! Thank You.
Old 12-27-2012, 05:45:49 PM
Exclamation Re: Kohler Model 1A21 Light Plant Plug Wire Size
Find a supplier of Packard 440 wire core ignition wire, or its equivalent. DO NOT use automotive wire. Lee pederson or H&M Enterprises will have the wire you newd. it is probably 7mm wire core ignition wire, black rubber jacket.
Both sellers mentioned are sponsers here on the Stak, look in the sponsers section. They will have the terminal ends and boots as well, if you need them.
Old 12-27-2012, 07:14:40 PM
Default Re: Kohler Model 1A21 Light Plant Plug Wire Size
Thanks so much Andrew, I appreciate you sharing your knowledge with me. Will take your advise and contact Lee Pederson or H&M Enterprises. Thanks for getting me back on track! I sure do want to see this old Kohler breathing once again, and with your help, I'm one step closer!
Tom
The Following User Says Thank You to TJ marnich For This Post:
kohler 1a21 how to wire question.. YellowLister Kohler Generators 7 12-25-2012 01:28:44 PM
kohler light plant 1a21 rocker oil tube question YellowLister Kohler Generators 3 12-17-2012 05:11:01 PM
1924 or 1925 Kohler Model D Light Plant TomFG Kohler Generators 5 08-20-2009 11:07:11 PM
B & S spark plug wire size kelby Small Air Cooled Gasoline Engines 5 03-20-2006 04:53:51 PM
kohler light plant model 3a21 Bill Kohler Generators 1 08-31-2002 12:39:15 AM
