Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Kohler Generators
Kohler Generators
Kohler Light Plant 2 KW, 110 VDC, Model KH needs regulator
this thread has 1 replies and has been viewed 1421 times
Old 05-23-2014, 11:21:49 PM
Wayne Johnson Wayne Johnson is offline
Default Kohler Light Plant 2 KW, 110 VDC, Model KH needs regulator
I have a Kohler Light Plant Generator 2 KW, 110 VDC, Model KH on eBay, but it has not sold. It's missing the regulator, any ideas where I can get one? It's working, but no one is bidding, maybe because of the missing regulator.
Thanks, Wayne
Here is a pic/
Old 05-24-2014, 02:01:48 PM
Vanman Vanman is offline
Default Re: Kohler Light Plant 2 KW, 110 VDC, Model KH needs regulator
I think the opening bid may be too high for a machine that's in such rough shape and is missing parts, but the fact that it does run and generate is a plus for sure. Being DC appeals to a smaller crowd than an AC one would.
What's missing isn't a regulator, but rather the automatic switch which enables load-sensing automatic starting and stopping. Those generators are compound wound, and thus are inherently self regulating with varying load.
To use it as it is you only need a shunt field resistor to set the output voltage to that which is desired. To make it electric start, just add a couple of batteries, a heavy switch, and a battery charging resistance, more or less.
If it was closer to me and, say $100 ~ $150, I'd still be interested. But I'm hundreds of miles away lol.
Keith
Kohler Model 1A21 Light Plant Plug Wire Size TJ marnich Kohler Generators 2 12-27-2012 07:14:40 PM
1924 or 1925 Kohler Model D Light Plant TomFG Kohler Generators 5 08-20-2009 11:07:11 PM
Kohler Light Plant ( 3.5 R 22 ) Carl Hangey Kohler Generators 1 10-12-2008 05:19:40 PM
KOHLER LIGHT PLANT DAVID M. LYON Kohler Generators 20 11-30-2003 09:25:39 PM
kohler light plant model 3a21 Bill Kohler Generators 1 08-31-2002 12:39:15 AM
