Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel and Oil Stationary Engines
Vintage Diesel and Oil Stationary Engines Fairbanks Morse, Lister, Petter, Witte and other pump injected Diesel oil engines.
Detroit Diesel 671
this thread has 4 replies and has been viewed 4019 times
Old 08-23-2014, 03:23:32 PM
DaytonEngines DaytonEngines is offline
Default Detroit Diesel 671
I have an International tandem dump truck with a 671 with no jake brake. I was wondering if putting an exhaust brake that I have would do any good. Would it harm the engine? Most people think jake brakes on detroits do not help much. I currently have a 671 and an 8V71 in trucks and they work very well in my opinion. Not as good as an old Cummins but still work quite well. Any thoughts would be appreciated.
Old 08-23-2014, 06:41:58 PM
Glenn Ayers Glenn Ayers is offline
Default Re: Detroit Diesel 671
You asked for my opinion .. so here goes;
I've driven trucks with exhaust brakes & they are about effective as stuffing a potato in your exhaust pipe. It sure keeps the engine from running well .... but not much "Braking" to it. Not worth the effort or cost (even if it was free) in my opinion. Get a Jake
Old 08-23-2014, 06:55:04 PM
MoRo's Avatar
MoRo MoRo is offline
The exhaust brakes are only good for quick warmups. Start the engine, throttle it up some and kick the brake on.
Old 08-23-2014, 07:32:12 PM
Tony Rye Tony Rye is offline
not sure they will work on a 2 stroke eng. don't ever remember one .but I worked on heavy equipment all my life
Old 08-23-2014, 08:49:06 PM
K-Tron K-Tron is offline
Series 71/92A Jake brakes are not difficult to find, and not very expensive. They typically run $35-75 a cylinder. You will need a valve cover spacer, or a taller cast aluminum valve cover for clearance. You will also need to install an in head oil line for lubrication and a clutch/neutral safety switch. Tee an oil line off of the governor/blower drive housing, or a port in the block, utilizing high pressure oil from the oil filter, or directly from the oil pump is not good for the jakes. I dont think a complete setup would cost you more than $500. The higher the compression, the more effective the exhaust brake will be. You might not get the same bark with a worn out engine as a fresh one. Naturally aspirated 6-71 (no turbocharger) run higher compression pistons, so the bark and braking power will be more noticeable than on a turbocharged engine. I cannot attest to how well they work on a 6-71, but they do work okay on my 4-53T and work great on my friends 6V92TA
Chris
ID Detroit Diesel? ichudov Multi-Cylinder Stationary Gasoline Engines and Power Units 36 12-01-2013 07:49:27 PM
Detroit Diesel in IHC W-30 B.L. Rodenkirch Antique Farm Tractors 5 11-11-2012 11:21:45 PM
Detroit Diesel Elec Power DDC25U with Diesel Perkins Engine Manuals? MP5ForTheWin Generators & Electric Motors General Discussion 4 08-14-2012 12:34:30 AM
Help With a Detroit Diesel 6-71 wild800 Generators & Electric Motors General Discussion 20 01-13-2012 10:22:11 PM
Detroit Diesel? harwill Generators & Electric Motors General Discussion 15 08-09-2010 08:30:56 PM
