Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel and Oil Stationary Engines
Vintage Diesel and Oil Stationary Engines Fairbanks Morse, Lister, Petter, Witte and other pump injected Diesel oil engines.
1-71 Detroit Diesel (GM)
this thread has 282 replies and has been viewed 36542 times
Old 12-18-2017, 08:59:37 PM
The Diesel Doctor The Diesel Doctor is offline
Smile Re: 1-71 Detroit Diesel (GM)
The fresh water pump is restored and mounted on the engine. The pumps original bearing was a non shielded one. Replaced it with a sealed one. Looked like oil could migrate and leak out the pump drain. I added a lip seal to keep this from happening. The cat o ring is the perfect size for the flange that seals the pump to the block. ALClick image for larger version
The Following 4 Users Say Thank You to The Diesel Doctor For This Post:
Old 12-28-2017, 02:08:50 AM
Default Re: 1-71 Detroit Diesel (GM)
Does anyone have the original cap for the 1-71 radiator? Its fits inside the filler neck and is for a non pressurized system. I could use the dimensions, OD, ID and distance between the tabs. Found some similar tractor caps online that i could modify to work. Thanks ALClick image for larger version
Old 12-28-2017, 07:34:42 AM
Nobby Nobby is offline
If you can wait a couple of days I have a hard copy of the Stant catalogue that lists in pictures/dimensions all the possible caps and it has not failed me yet. So if you can post dimensions on Sat I can look it up, I'd bet that it was a standard size.
Cheers
Nobby
The Following User Says Thank You to Nobby For This Post:
  #204
Old 12-28-2017, 12:59:17 PM
Thanks Nobby ALClick image for larger version
Old 12-28-2017, 09:28:49 PM
Mbetti Mbetti is offline
I had no luck coming up with a replacement, if I remember, there is one in Steiner Tractor that might work.
ID:	299225   Click image for larger version
The Following User Says Thank You to Mbetti For This Post:
  #206
Old 12-31-2017, 05:06:28 PM
Happy New Year to everyone on Smokstak You shared a wealth of information in 2017. Looking forward to 2018. ALOHA AL
  #207
Old 01-03-2018, 10:19:04 AM
Sorry for delay, looks like the closest your going to get is the Tractor fuel tank style with the chrome rounded cap - 10623
Cheers
Nobby
  #208
Old 01-13-2018, 12:21:07 AM
I am making great progress on my radiator core. As mentioned in previous posts, There was no radiator shop in Hawaii that could do the job or help me. I contacted CG & J in Gadspen AL. They made me a core to the specs and measurements i gave them. They did a remarkable job at a very reasonable cost. Going to practice my tinning and soldering skills before i attach my tanks. ALClick image for larger version
  #209
Old 01-17-2018, 12:24:28 AM
Need some input PRO or CON on painting a radiator. I soldered on the tanks and tested it to 7 psi. It looks good now being made of brass and copper. However it is hidden in a cast iron shell and you cant see it. Living on an island in the middle of the Pacific it`s a very salty environment. In a couple months it will start turning green. Eastwood makes a heat aerosol radiator paint. AL
Old 01-17-2018, 06:31:09 AM
Elden DuRand's Avatar
Go ahead and paint it. Stave off corrosion.
[SIGPIC][/SIGPIC]
Take care - Elden
http://www.eldensengines.com
  #211
Old 01-17-2018, 08:50:53 AM
mschreiber mschreiber is offline
i've had good luck with hi-heat stove paint from ace hrdwr. my 13000 core is mostly hid too. btw i didn't do any specific research other than noting how well it held up on my wood burner. good luck.
The Following User Says Thank You to mschreiber For This Post:
  #212
Old 01-17-2018, 08:52:33 AM
Sooty Jim Sooty Jim is offline
Yeah, paint it! We won't rat you out to the originality cops ( : < ).
The Following User Says Thank You to Sooty Jim For This Post:
  #213
Old 01-17-2018, 09:58:44 AM
ronm ronm is offline
Any radiator should be flat black, it helps them "radiate" better...
Smokstak member #442
The Following 2 Users Say Thank You to ronm For This Post:
  #214
Old 01-17-2018, 11:06:29 AM
I have an old report on file that discusses paint colour for best radiation on cast iron radiators and Terra Cotta was the best! Now that would be a show stopper a Terra Cotta painted 1-71.
Cheers
Nobby
  #215
Old 01-19-2018, 12:11:35 AM
Radiator finished Before and after. ALClick image for larger version
The Following 7 Users Say Thank You to The Diesel Doctor For This Post:
  #216
Old 01-19-2018, 12:16:56 AM
wow. that looks good.
The Following User Says Thank You to slip knot For This Post:
  #217
Old 01-27-2018, 03:32:27 AM
Customer sent me photos from 33 years ago of replacing a cylinder block and crank in a 8v-53 marine engine in his boat. Check out the lifting rigs. It`s a wonder that i am still alive. I have greatly improved my rigging and housekeeping skills. AL .Click image for larger version
Old 01-27-2018, 06:30:25 AM
Heh heh. Is that one of those careers where you'd rather be lucky than good?
[SIGPIC][/SIGPIC]
Take care - Elden
Old 01-27-2018, 09:02:28 AM
Hah! That's a "git 'er done" moment for sure.
I had a leather bill like that too.. just about 10 years earlier.
Working on marine engines can be a lot like yoga. Instead of Hatha Yoga, it's "Greasy Yoga." You have to be a weightlifting contortionist.
I have two memorable moments in my short marine engineering career:
Dismantling and bringing the majority of a 6-110 in pieces up two decks out of the generator room using chain falls. Going down was easier.
The other was being in a crew rebuilding a 1,200 hp Atlas Imperial in a 100 foot tug. Literally had to torch a good part of the superstructure off and set it on the pier using a 12 ton crane, then tearing the engine down and lifting those pieces into specially prepared crates for shipping to a machining facility in Norfolk.
Old 02-03-2018, 02:24:35 AM
Doing an in frame rebuild on a 8V 71N. Breaking in the new deckhand. ALClick image for larger version
The Following 2 Users Say Thank You to The Diesel Doctor For This Post:
1-71 Detroit Diesel (GM) The Diesel Doctor Vintage Diesel and Oil Stationary Engines 3 05-21-2016 05:30:26 PM
Detroit Diesel 8-71T Oil in Air Box Tim in Mexico Vintage Diesel and Oil Stationary Engines 11 10-10-2015 08:19:25 PM
Detroit Diesel 671 DaytonEngines Vintage Diesel and Oil Stationary Engines 4 08-23-2014 08:49:06 PM
Detroit Diesel Elec Power DDC25U with Diesel Perkins Engine Manuals? MP5ForTheWin Generators & Electric Motors General Discussion 4 08-14-2012 12:34:30 AM
Gen. set wtd. Detroit Diesel Denny Foster Generators & Electric Motors General Discussion 0 11-13-2000 10:06:06 PM
