Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Kohler Generators
Kohler Generators
Kohler Model B Light Plant - What Magneto
this thread has 11 replies and has been viewed 915 times
Old 05-08-2018, 10:07:49 AM
decoy64 decoy64 is offline
Default Kohler Model B Light Plant - What Magneto
Stumbled across a Kohler Model B light plant at a swap meet the other day, and just had to have it. It is missing the magneto, though. What mag was used on these plants? Is it the same as the 1A21 plants?
Just trying to figure out which one to keep an eye out for...
If I remember, I will post some pictures in the "as Found" state. It seems to be complete with the exception of the mag, Only damage being a cracked exhaust manifold.
Thanks!
Old 05-08-2018, 12:36:12 PM
Vanman Vanman is offline
Default Re: Kohler Model B Light Plant - What magneto
Model B.... Is it the little overhead valve, water cooled inline four? Radiator above the generator? Then, yes, ought to be the same engine as a 1A21. Seems that quite a few different mags were used on those. Suspect it's a fairly standard type.
Oh, yes, please post some photos. Especially the nameplate.
Old 05-08-2018, 01:23:54 PM
BHoward BHoward is offline
I have a B Kohler that I have sold some parts off. Is there a fine spline cup on the end of the governor? I,m sending a picture of the coupling that goes on the mag
Old 05-08-2018, 01:25:52 PM
Here,s the plate on mine
The Following User Says Thank You to BHoward For This Post:
Old 05-08-2018, 03:09:13 PM
Default Re: Kohler Model B Light Plant - What Magneto
Both my plants have Farebanks Morse mags .
Old 05-08-2018, 06:32:44 PM
Exclamation Re: Kohler Model B Light Plant - What Magneto
The mags from any of the 4 cylinder OHV sets (A-E and 1A & M 21s) should fit. You will need to install a matching set of splined couplings though - they had several different ones. They used WICO, Eismann and F/M magnetos over the years.
Old 05-08-2018, 08:50:07 PM
You guys are quick... Here are some pictures. I am going to go out to the garage right now and get one of the mag coupling. I'm pretty sure it looks like the one you posted, bHoward. If anyone has a specific model/type of mag, I have a buddy that has a ton of 4 cyl mags he bought in a sale, just need to shoot him a model ID of one that will work.
Thanks!
Griffin
ID:	310035   Click image for larger version
ID:	310036   Click image for larger version
Old 05-08-2018, 10:33:44 PM
Here's the magneto drive coupling
Old 05-09-2018, 07:38:42 AM
The mag that was on my B was a Farebanks Morse J. It had a spacer plate on the bottom. The plate and the spline piece are available . I don't need them. I put the mag on Farbanks engine.
Old 05-09-2018, 07:40:43 AM
Here,s the spacer
Old 05-09-2018, 09:41:11 AM
BHoward, if those pieces are available, what do you want for them? They could come in handy You can PM me with details if you would like.
Thanks,
-Griffin
Old 05-09-2018, 07:18:14 PM
Grape Grape is offline
Griffin, if Bill has the parts you need you can be confident he will treat you right. I got a few nice parts from him in the past for mine and all were well worth the price.
Have fun with your new toy.
Phil Grape
Remember, to Belittle others is to Be Little yourself
Kohler Light Plant 2 KW, 110 VDC, Model KH needs regulator Wayne Johnson Kohler Generators 1 05-24-2014 02:01:48 PM
Kohler Model 1A21 Light Plant Plug Wire Size TJ marnich Kohler Generators 2 12-27-2012 07:14:40 PM
1924 or 1925 Kohler Model D Light Plant TomFG Kohler Generators 5 08-20-2009 11:07:11 PM
Kohler light plant magneto needed Keith Kinney Kohler Generators 8 02-09-2005 06:21:33 PM
kohler light plant model 3a21 Bill Kohler Generators 1 08-31-2002 12:39:15 AM
