Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Honda, Yamaha, Kawasaki, Isuszu Generators
Honda EU3000is SN - manufacturing date?
this thread has 8 replies and has been viewed 436 times
Old 08-21-2019, 12:58:23 PM
Moose22 Moose22 is offline
Default Honda EU3000is SN - manufacturing date?
Considering buying a used Honda Eu3000is Generator SN: EZGF 1304110. Would appreciate any help to identify manufacturing year and whether there were any issues (recalls, performance) with this model.
Old 08-22-2019, 09:21:11 AM
StringJ StringJ is offline
Default Re: Honda EU3000is SN - manufacturing date?
https://powerequipment.honda.com/sup...ls-and-updates
The above link shows Honda recalls and I don't see one for the EU3000is. I have looked but can't find anything about decoding the serial number to find the date. I found this site but it doesn't help.
https://goseoiqseo.netlify.com/honda...al-number.html
Jerry
Old 08-23-2019, 01:03:23 AM
I recall seeing a post here where a Honda employee provided detailed information on a serial # but that info doesn't appear to be available to the public. Thanks for reply Jerry.
Old 08-23-2019, 08:52:00 AM
That would have been Robert@Honda. Something happened with him as he dropped off the Internet. That's a shame as he was very helpful on many forums.
Jerry
Old 09-11-2019, 03:47:04 AM
Default Re: Honda Generator won't run furnace
Recently we tried to start the furnace using the Honda EU2000i generator and discovered it wouldn’t start-up. The generator has an eco-mode (lower idle) and a non-econo mode (higher rpms) - neither would start the furnace.
The EU2000i has a maximum output of 13.3 amps.
Lennox high efficiency furnace is 120 V 60 hz 1 ph 12 amps.
Furnace error code confirms ‘Improper earth ground’.
I've tried grounding the generator directly to the house's primary water ground w/o success. All other attempts to ground continue to bring up the ground error code.
Any suggestions would be greatly appreciated.
Old 09-11-2019, 07:26:28 AM
I could be far off here, but it seems like someone had that problem and the fix was connecting the ground and the neutral together in a three prong plug and then plugging that into one of the sockets on the front of the Honda.
Jerry
Old 09-11-2019, 11:23:30 PM
turtmaster turtmaster is offline
It's a gas furnace, and it needs a neutral ground Bond, in order for the flame detection circuitry to work.
Old 09-13-2019, 03:53:02 PM
Default Re: Honda EU2000i - proper ground for gas furnace
http://ricksdiy.com/generators/porta...-honda-yamaha/
(Thanks to StringJ and Turtmaster for the tip)
The Following User Says Thank You to Moose22 For This Post:
Old 09-17-2019, 09:59:27 PM
Default Honda EU2000i - proper ground for gas furnace
Update on the NB ground plug - this solved the problem!
Ran the furnace off one of our EU2000i's on eco-mode and the gen didn't even rev up!
Such an easy fix that even the local experienced furnace dealer, Lennox themselves and 2 electricians didn't know.
Thanks again!
Honda EU3000is Springhook Machine Shop and Tool Talk 2 06-06-2019 05:32:30 PM
Honda EU3000is Wheels Noblng Honda, Yamaha, Kawasaki, Isuszu Generators 1 06-25-2016 06:20:13 PM
Honda EU3000is oil recommendation JBecker Honda, Yamaha, Kawasaki, Isuszu Generators 1 02-21-2016 11:26:32 PM
Honda EU3000is Generator Twin34 Honda, Yamaha, Kawasaki, Isuszu Generators 6 03-17-2014 06:39:57 PM
Honda EU3000iS won't start Schwen Honda, Yamaha, Kawasaki, Isuszu Generators 9 02-09-2014 01:30:40 AM
