Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles > Horse Drawn Equipment
Horse Drawn Equipment Old iron designed for the purpose of hitching up to a horse or a team. This old iron machinery may be used or demonstrated while hooked to an old iron tractor too.
Steel wheeled wagon
this thread has 2 replies and has been viewed 5001 times
Old 09-01-2010, 11:54:43 PM
JIMnWV JIMnWV is offline
eMail NOT Working
Default Steel wheeled wagon
My Wife and I Bought this Wagon out in Peoria, Ill a while back, Does Anyone Recognize anything that might Help lead to a Manufacturers Name? I Found a patent date that appears to be 1913 on a casting on the Tounge. Seems to be in Pretty Solid condition.
Name:	Cindy's Wagon 023.JPG
ID:	86418   Click image for larger version
Name:	Cindy's Wagon 020.JPG
ID:	86419   Click image for larger version
Name:	Cindy's Wagon 026.JPG
ID:	86420   Click image for larger version
Name:	Cindy's Wagon 025.JPG
The Following User Says Thank You to JIMnWV For This Post:
Old 09-01-2010, 11:59:08 PM
eMail NOT Working
Default Re: Steel wheeled wagon
A couple more pics...
Name:	Cindy's Wagon 021.JPG
ID:	86422   Click image for larger version
Name:	Cindy's Wagon 022.JPG
ID:	86423   Click image for larger version
Name:	Cindy's Wagon 019.JPG
Old 09-30-2010, 08:09:00 PM
Avery22x36 Avery22x36 is offline
There is a cast iron piece that the reach (center beam between axles) goes through where it meets two braces that angle toward both ends of the rear axle. The top of the casting often has a name or initials. Example- WW =Webber Wagon, I've seen Monkey Ward, Mitchel and several other name brands marked in the casting. Sometimes the fifthwheel (turntable on front axle) will have a marking, the one in the shop right now has an IHC in it. I have seen a good number that are unmarked but you can usually identify little things that put it in one of the wagon familys.
---------- Post added at 07:09 PM ---------- Previous post was at 07:07 PM ----------
PS: I am pretty sure that tongue assembly was an aftermarket, its seen pretty often on different brands of wagons.
Old steel wheeled tractor in a movie model k rumely Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 54 12-30-2016 04:41:01 PM
Street bands for steel wheeled tractor SAB Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 08-23-2010 10:13:12 AM
Steel Wheeled Snow Plow Rex Piekarczyk Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 23 09-07-2009 10:12:25 PM
Odd engine on steel wheeled tiller Farmboy1 Antique Gas Engine Discussion 4 12-21-2008 02:15:44 PM
Tractor Pulling With Steel Wheeled Antiques Tony Thompson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 19 07-17-2008 04:49:07 AM
