Delco Light Plant
this thread has 5 replies and has been viewed 727 times
Old 08-30-2018, 11:15:23 PM
Slimfinnish Slimfinnish is offline
Default Delco Light Plant
Does anyone know what kind of ignition points they use. Im having trouble with my Delco generator burning points. Thanks Leonard
Old 08-31-2018, 11:21:39 AM
radiodoc radiodoc is offline
Default Re: Delco light plant
Sounds like the capacitor is bad.
Old 09-05-2018, 11:56:07 PM
Default Re: Delco Light Plant
Does anyone have ignition points for the one cylinder engine. Is there a substitute for the points.
Old 09-06-2018, 09:44:39 AM
cammer cammer is offline
i used the complete ignition plate from a 390 ford engine looks original . youtube restored delco light plant and both running it,s on one of them
Old 09-06-2018, 12:28:45 PM
Mike Schweikert's Avatar
Early Lincoln and Packard used very similar points
That is what I used on my 752
Mike Schweikert
Jamison PA
Old 09-07-2018, 06:25:39 PM
44dwarf 44dwarf is offline
My 4b12 was drilled and taped to take ford tractor points i just had to cut off the tab on the backing plate that holds the connection point for the coil wire. Change the condenser and add a ballast resistor from a 60's points fired MOPAR will make them live longer. The resistor goes in the +12v wire to the ign coil.
Identifying Delco-Light light plant WesPete66 Delco and other Low Voltage DC Light Plants 6 10-20-2010 06:41:59 AM
Delco light plant? darrin Delco and other Low Voltage DC Light Plants 11 09-30-2009 01:57:17 PM
Delco Light plant Don C. Wiley Delco and other Low Voltage DC Light Plants 3 04-28-2009 07:43:55 PM
Delco Light Plant Acadia John Delco and other Low Voltage DC Light Plants 1 01-27-2009 12:37:14 PM
Delco light plant ldj1002 Delco and other Low Voltage DC Light Plants 1 07-27-2004 11:41:45 PM
