Delco light plant
this thread has 10 replies and has been viewed 2052 times
Old 08-22-2015, 10:09:02 PM
gakeim gakeim is offline
Default Delco light plant
Have a Delco light plant here, it's a fairly big one and anyone know what model it is?
Old 08-25-2015, 08:40:24 PM
Default Re: Delco light plant
Have some more pictures here. Also, if someone knows what model the red Delco is, that would be great
ID:	232859   Click image for larger version
ID:	232860   Click image for larger version
ID:	232861   Click image for larger version
Old 09-01-2015, 08:18:53 PM
NDmeterman NDmeterman is offline
If the meter on that one light plant was a Sangamo, be careful handling it - it's a mercury-motor meter.
Old 09-01-2015, 09:57:55 PM
All I can tell you is that the red one was rebuilt at the Delco plant sometime during its life. Here's a good place to start though:
http://delcolight.com/10.html
Google "antique light plants" and a couple of good sites will pop up.
The Following User Says Thank You to George Andreasen For This Post:
Old 09-02-2015, 10:46:43 AM
Frank DeWitt Frank DeWitt is offline
This might help
http://lbpinc.com/Light-Plant/d-id.jpg
Old 09-04-2015, 11:38:59 PM
Good to know, turns out it is indeed mercury
Old 09-05-2015, 11:20:59 AM
OK, Now you got me. What is a mercury motor and how does it work?
Old 09-05-2015, 01:28:29 PM
While I think what NOM meant was that it was a mercury motor-meter, the old Sanskrit legends of a Golden Age included flying machines powered by mercury motors---unfortunately they also seemed to have weapons that could be cast afar, went off brighter than the sun, caught elephants on fire (not their coverings, the elephants themselves) and, if you were far enough away you weren't killed, contained a deadly poison, the only defense to it being to jump into a river and thoroughly wash everything off...
So I do hope that was not a mercury powered motor...
Old 09-05-2015, 08:50:42 PM
Dale Burkman Dale Burkman is offline
The black one is a model 850. The red one is a model 8C3. The 8C3 was red new from the factory. Dale Burkman
Old 10-18-2015, 06:43:43 PM
L Steiner L Steiner is offline
The plant looks like an 850 auto shut off.
Old 01-07-2016, 08:42:44 PM
netpirate8 netpirate8 is offline
What you have there is an early model Delco Light Plant. Model: 9004. Which is simply an 850. What gives it away is the dual knife switches. I have one just like it.
Delco light plant Mike in CA Delco and other Low Voltage DC Light Plants 1 01-29-2009 12:51:40 AM
Delco Light Plant Acadia John Delco and other Low Voltage DC Light Plants 1 01-27-2009 12:37:14 PM
Delco 32V light plant value? Paul Garvey Delco and other Low Voltage DC Light Plants 18 02-21-2007 06:11:59 PM
Delco light plant Graham Jones Delco and other Low Voltage DC Light Plants 3 10-17-2003 12:11:54 PM
