Delco light plant
this thread has 2 replies and has been viewed 1657 times
Old 09-05-2003, 08:28:11 PM
Bob Shannon
Default Delco light plant
In need of a fuel pump for a model 752 Delco light plant. Thanks
Old 10-14-2003, 09:24:14 PM
art zeman
Default Re: Delco light plant
I too need a fuel pump for my 750. Mine is starting to crumble and is leaking.It looks like a fuel pump from an old car but I can't rember what make. have to look into this .
Old 10-15-2003, 10:52:33 AM
Don C. Wiley
Bob and Art;
The fuel pump you are looking for is not a common automobile pump. I think the top will interchange with a lot of the old car pumps but the bottom is special. The car pump had an arm that run on a cam on the cam shaft. The Delco-Light pump runs off of a connecting rod to a small crankshaft on the end of the cam shaft. To get this connected the bottom of the Delco-Light pump has a removable cover to make this connection.
There may be some rare car pumps that had the cover but I don't know of any. The best way to fix that is to find an original pump. You might even have to find another parts generator with a pump on it. Most of the ones I see have the pump missing.
If any one has a connection to get these fuel pumps please let me know.
"DELCO DON" Southern Illinois
Delco Light Plant wydiver Delco and other Low Voltage DC Light Plants 7 03-24-2011 04:38:28 PM
Delco light plant Mike in CA Delco and other Low Voltage DC Light Plants 1 01-29-2009 12:51:40 AM
Delco light plant toytech40 Delco and other Low Voltage DC Light Plants 9 12-16-2008 09:10:58 PM
Delco light plant jon olsen Delco and other Low Voltage DC Light Plants 1 09-05-2004 12:15:35 AM
