Dean HomeLite System info wanted
this thread has 1 replies and has been viewed 325 times
Old 05-30-2019, 03:59:25 PM
oldiesteam's Avatar
oldiesteam oldiesteam is offline
Default Dean HomeLite System info wanted
I'm looking for any information at all on my Dean Homelite set. It's currently hooked to a 1hp Gray that was modified to be a throttler not sure the engine went with the rest of it but the Control panel and Generator are a matched set plus they do work. Any help with info, other dean electric products I could hook up to it would be great.
ID:	335926   Click image for larger version
The Following 3 Users Say Thank You to oldiesteam For This Post:
Old 05-31-2019, 06:11:07 AM
GeneratorGus's Avatar
GeneratorGus GeneratorGus is offline
Default Re: Dean HomeLite System info wanted
Sorry, nothing much to help, but way cool. Neat little set.
Something about the Dean and the Gray engine have me thinking I have the my little bell ringing, and it's not the tinnitus.
GUS
The Following User Says Thank You to GeneratorGus For This Post:
Gray throttler with Dean Homelight System oldiesteam Hit & Miss Gas Engine Discussion 10 10-11-2019 08:35:47 AM
Homelite 7-29 and 8-29 saws wanted CM76 Chain Saw Collectors 11 06-12-2017 05:47:04 AM
Ignition System Info thiggy Hit & Miss Gas Engine Discussion 7 09-10-2013 09:08:18 PM
Homelite String trimmer fuel system help oldschoolwisconsin Small Air Cooled Gasoline Engines 29 06-09-2012 07:19:48 PM
Homelite 9-26, 900G - 995G chainsaws wanted CM76 Chain Saw Collectors 4 03-29-2012 01:59:50 PM
