Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Antique Engine Photos
Antique Engine Photos OLD gas engines, hot air engines, Diesels and steam engines. An electronic photo gallery to showcase the best of your old engine collection.
Goulds Pump
this thread has 7 replies and has been viewed 1135 times
Old 09-23-2017, 08:37:39 PM
DaveRW DaveRW is offline
Images: 3
Default Goulds Pump
I hope I placed this post in the right place. What type of an engine was used to run this pump? It has a chain drive with a clutch.
Name:	Goulds Pump 001.JPG
ID:	292038   Click image for larger version
Name:	Goulds Pump 002.JPG
Old 09-23-2017, 08:52:17 PM
Tom Geier's Avatar
Tom Geier Tom Geier is offline
Images: 51
Default Re: Goulds Pump
It is a goulds pyramid pump
Do i really look like a people person?
Old 09-23-2017, 09:06:34 PM
Images: 3
Thanks for the reply. Can you tell me the horsepower of the engine used to run this pump and the revolutions per minute it should be ran at?
Old 09-23-2017, 09:50:25 PM
Gene Williams Gene Williams is offline
Going to do one of these over the winter. Any special things to know about or pay extra attention to when we are in there?
Old 09-23-2017, 10:25:36 PM
Glenn Gieszler Glenn Gieszler is offline
Book does not give horsepower as it could have been run on by line shaft
You would find it on the pump curve chart for a figure 1531 pyramid pump
Rated at 40 rpm 75 psi at 175 ft/hd
Pulley diameter is given best to know the bore & stroke and suction and discharge sizes
Old 09-23-2017, 11:34:43 PM
Tom Geier's Avatar
Images: 51
https://www.smokstak.com/forum/showthread.php?t=84775
The Following User Says Thank You to Tom Geier For This Post:
Old 09-24-2017, 12:02:13 AM
Images: 3
Thanks Glenn for the information this pump is a 3 x 5. The inlet, outlet 1-1/2 inch and the sprocket is 8 inch diameter.
---------- Post added at 11:02:13 PM ---------- Previous post was at 10:40:59 PM ----------
Gene; this pump was stuck when I receive it from the salvage yard I work at. I had to polish both shafts and reshim the top one. A little heat and oil loosened the clutch and the piston plunger assembly. I will also have to polish the piston glides. I will need new piston leather cups and new rubber check valves. I do not know if I worded all of the pump parts correctly. But it looks pretty self-explanatory.
The Following User Says Thank You to DaveRW For This Post:
Old 09-24-2017, 08:15:17 PM
John Drabik's Avatar
John Drabik John Drabik is offline
I did one over a few years ago. Hardest part was facing the bronzeish seats. They are probably removeable but I didnt want to risk breaking them. Mine were rather pounded and no longer flat. I used a piece of round stock that spanned the seat drilled it thru and used the center stud as a pilot, glued a piece of abrasive cloth to it and just kept twisting it by hand. Did an acceptable job. Used sheet neoprene and a custom made washer for the valve itself.
It pumps okay. Certainly good enough for show purposes. Next time Ill try making valves with sheet phenolic with rubber bonded to it.
Goulds Pump Al Wait Antique Gas Engine Discussion 4 10-24-2018 09:39:14 AM
Goulds pump ID MCanady Farm + Industrial Antiques and Collectibles 1 10-22-2013 07:59:43 PM
Goulds pump Nate Bolduc Antique Gas Engine Discussion 3 07-18-2011 08:52:19 PM
