Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Antique Engine Photos
Antique Engine Photos OLD gas engines, hot air engines, Diesels and steam engines. An electronic photo gallery to showcase the best of your old engine collection.
Old Cars Used as Engines?
this thread has 18 replies and has been viewed 2387 times
Old 01-16-2018, 12:26:53 AM
fumo fumo is offline
Default Re: Old Cars Used as Engines?
We had a Star 4 engine setup like Typak's youtube video. Good engine.
Old 02-20-2018, 09:46:52 PM
I took a minute to photo this pulley.
it is a 21 inch demount-able wheel from a 26 T car.
I doubt the car would be driven very far with this installed. The owner probably would have just putt putted around the farm in low gear.
This is hub,brake drum and all. I have no knowledge of the history of this as it was just handed to me 1 day at a tech session with the model T club I am in. They know I gather odd stuff!.
ID:	303614   Click image for larger version
The Following User Says Thank You to uglyblue66 For This Post:
Old 03-18-2018, 11:39:53 PM
EmersonFan EmersonFan is offline
Growing up on a farm in southern MO in the 1970s, I remember seeing several small sawmills that were made from old cars. NOT just for cutting a log into firewood; we used chainsaws for that. These were real sawmills that could cut a sawlog into planking of various sizes and shaped to build a barn or a house. In one case, a Model T was pretty much stripped of everything but the engine, transmission, drive shaft, differential, and one wheel where the saw blade was installed. In the other case, some old 40s car had been more modified - the engine was bolted sideways and I don't know why the engine was moved.
Old 03-19-2018, 12:49:34 AM
Ifix71 Ifix71 is offline
Dad used a Nash to drive the Silage blower so the H could pull the wagons from the field donít think he did that long I also remember a MM U working hard on the belt got to get mom to look For pictures Dad liked to take pictures had a developer and a dark room boy thatís come along way
The Following User Says Thank You to Ifix71 For This Post:
Old 03-19-2018, 10:27:34 AM
My grand-pals Turner sawmill that is still down behind his house was run by a 50's 223 6 cylinder Ford car engine and transmission. The chassis was cut behind the trans,it was in 2'd gear.A throttle lever mounted on the main 1 to make the carriage move accelerated the engine when the saw hit wood.From what I understand the previous owner of the mill set it up this way using the wrecked car with low miles as a power unit back in the late 50's and it was used at his place until the early 70's when grand-pal got it. It was run until about 1990 and grand-pal got sick and I don't guess it has been run much since.
Old 03-19-2018, 11:09:14 AM
JoeCB JoeCB is offline
That pulley set-up looks like it was purpose made for that Model T application... a commercial manufactured item. They did make a lot of aftermarket stuff for "T's"
Joe B
Old 03-21-2018, 11:18:25 AM
Tom Winland's Avatar
Tom Winland Tom Winland is offline
Banner Sponsor
Images: 8
I took a 15 hp Reid out of a pumphouse years age that had a old car up on blocks with a belt around the rim over the engine flywheel to pump the oil but did not take any pictures. The car is still there probably
Tom Winland
Ohio
http://gasenginetom.com
CHECK OUT MY ENGINE VIDEOS AT
http://www.youtube.com/user/gasenginetom
The Following User Says Thank You to Tom Winland For This Post:
Old 03-27-2018, 05:39:26 AM
BMiller's Avatar
BMiller BMiller is offline
Tom, you might want to check that out. Guys are paying good money for a rust spot on the ground, then restoring it. That car might be worth something.
Old 04-02-2018, 03:19:51 PM
OTTO-Sawyer's Avatar
Thumbs up Re: Old Cars used as engines ?
Originally Posted by typak View Post
a video of a T and sawbench at work.
https://www.youtube.com/watch?v=0U31vL8s-uE
Beautiful Video Tribute typak.
Your Dad Would Be Proud.
I subscribed to your channel while I was there.
Huber & Case Steam Tractors, Collector Cars, Trucks, Race Cars-Twin Oaks Auction. salvageprincess Live Auctions of Engines, Tractors and Old Iron 3 05-17-2014 11:12:07 PM
cars Cars CARS! The Harold Lemay Collection Craig A Antique Autos and Trucks 6 04-25-2012 07:36:14 PM
Reason why Engines, Tractors, Cars and Implements cost more in Canada. Denis Rouleau Antique Gas Engine Discussion 12 02-12-2010 08:16:00 PM
Engines and Parts for Antique Cars and Trucks Harry Antique Autos and Trucks 0 02-18-2007 02:51:50 PM
