Witte CD 10 hp Needs a Piston and Injection
this thread has 8 replies and has been viewed 1235 times
Old 03-30-2018, 11:18:36 AM
smokewitte smokewitte is offline
Exclamation Witte cd 10 hp project need help
HI FOLKS
MY NAME IS TAHAR I'M FROM MOROCCO I HAVE A WITTE CD 10 HP NOT RUNNING FOR 23 YEARS BECAUSE THE PISTON IS MESSED UP AND I REALLY NEED YOUR HELP TO FIX IT ALSO IF YOU KNOW WERE I CAN GET SOME PARTS TO BACK IT UP TO LIFE AGAIN
AND HERE IS SOMME PICTURES OF IT SHOWING ITS CONDITION
IT REALLY NEEDS CARE
ID:	306953   Click image for larger version
ID:	306954   Click image for larger version
ID:	306955   Click image for larger version
Old 03-31-2018, 07:42:38 AM
Unhappy Witte CD 10 hp Needs a Piston and Injection
hi folks
im having a witte cd 10 hp not runing fo 23 years . the piston is missing but all the other parts working perfectly i really need your help; also in any one have somme manuals would help to fix its problems. and thanks
this is my email : tahareilighe@gmail.com
and this is some pictures explaining its condition
https://drive.google.com/open?id=1oh..._eEzEvkeNxdo2w
Old 04-24-2018, 07:50:46 AM
Exclamation Witte CD 10 hp Need Parts Builder Please
hi everyone
please i need parts for witte cd 10 hp
piston and sylinder
injector
gas pump
air filter
and thanks
Old 04-25-2018, 05:31:49 PM
Photo Witte bd 7.5 hp needed piston and injection
HI FOLKS
IM HAVING A WITTE BD 7.5 HP NOT RUNUNG FOR 23 YEARS AND I REALLY NEED YOUR HELP TO MAKE IT RUNING AGAINE SO FIRST OF ALL I GOOGLED THE NET LOKING FOR NEW PARTS FOR IT AND I REALLY GOT A LOT OF INFORMATION FROM YOUR PREVIEOS POSTS I REALLY APPRECIATE YOUR EFFORTS SO I BOUGHT SOMME NEDED PARTS (Lift Pump With Diaphragm,Lister CS Bosch Mico Fuel Pump,AIR FILTER ) AS YOU WILL FIND IN THE PICTERS ABOVE BUT THE PROBLEM IS I HAVE A BROKING PISTON,HEAD GASKET AND INJECTION TOO SO PLEASE ANYONE HAVE ANYTHING HELPFUL TO SHARE WITH ME IT WOULD BE BETTER IN SORT OF MANUALS PART NUMBERS...
AND THANKS AGAINE
TAHAR
ID:	309076   Click image for larger version
ID:	309077   Click image for larger version
Old 04-25-2018, 05:45:01 PM
Post Witte BD 7.5 hp Needed Piston and Injection
HI FOLKS
AND THANKS AGAINE
TAHAR
ID:	309079   Click image for larger version
ID:	309080   Click image for larger version
ID:	309081   Click image for larger version
Old 04-26-2018, 08:46:15 AM
Grigg Grigg is offline
Default Re: Witte CD 10 hp Needs a Piston and Injection
There aren't many parts available off the shelf these days.
Head gasket you can have made, another member details some of that process lately.
I'm not aware of any source for new pistons or cylinder liners. Best bet is finding a piston, even used, and having existing liner bored and sleeved to fit piston on hand. Or all used parts.
The fuel pump you show won't work as is, but it's possible you can mix and match using the long lever from an original pump. I've researched this previously and couldn't find any other application that used an AC pump with the same long pump finger/lever that Witte used.
Parts can be found and made, but it takes some research and leg work, having old now obsolete part numbers won't get you very far.
Keep reading about Witte's on this forum, there is a lot of info here and other resources listed.
The Following User Says Thank You to Grigg For This Post:
Old 04-26-2018, 11:45:21 AM
ok sir thanks soo much i just read everything you posted about your witte project and i really learn a lot from you also i still learn and read about those engins as well if you can provide me please with (manuals,parts numbers any ) anything would help it would be better and thanks so much
this is my email:tahareilighe@gmail.com
Old 04-26-2018, 04:06:19 PM
Fig Fig is offline
I've been searching for oil pump parts for my MD12 for years with no luck.
Old 04-26-2018, 08:42:54 PM
Hi bro
did you try with arrow engins company i thing they might have somthing
and goode luck bro
tahar
Witte NOS Injection Nozzles Chuck Moss Vintage Diesel and Oil Engines 6 03-21-2017 11:07:21 PM
Witte Fuel Injection Pump Jud Vintage Diesel and Oil Engines 19 02-22-2017 02:28:48 PM
Witte Diesel Injection Pump danefan Vintage Diesel and Oil Engines 2 09-14-2015 06:28:39 AM
Witte CD-12 Injection pump question Danjohn Vintage Diesel and Oil Engines 2 04-16-2015 08:58:34 PM
Witte Fuel Injection Pump Jud Generators & Electric Motors General Discussion 0 06-14-2007 07:18:01 PM
