Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Antique Engine Photos
Antique Engine Photos OLD gas engines, hot air engines, Diesels and steam engines. An electronic photo gallery to showcase the best of your old engine collection.
Does anyone know what kind of engine this is?
this thread has 15 replies and has been viewed 9423 times
Old 03-28-2008, 10:09:23 PM
Chuck R Chuck R is offline
Images: 1
Photo Does anyone know what kind of engine this is?
I am trying to find out if anyone knows what kind of engine this is, I have been given a couple of different opinions. There are no tags numbers or any identifing marks on it.
Old 03-29-2008, 07:23:34 AM
Doug Kimball's Avatar
Images: 78
Default Re: Does anyone know what kind of engine this is?
Chuck,
Get a number off the Webster ignitor/bracket .... you may have to release mag. Unusual hopper opening.
The Following User Says Thank You to Doug Kimball For This Post:
Old 03-29-2008, 10:12:14 AM
GW Eddy GW Eddy is offline
It can be a George B Miller these had several diffrent trade names
The Following User Says Thank You to GW Eddy For This Post:
Old 03-29-2008, 10:52:12 AM
Farmboy1 Farmboy1 is offline
looks kind of like an assosiated
Old 03-29-2008, 12:50:02 PM
Mike Otis Mike Otis is offline
I know where thre is one like it but no name on it ethier
Old 03-29-2008, 11:47:35 PM
Robert Haus Robert Haus is offline
I agree with Doug...get those numbers off the bracket/mag....
The new variations of the "big yellow book" have an appendix of these numbers and what they went to.....it would enable you to narrow it down quite a bit I would suspect...if you don't have the book with the numbers, post them here and someone will be able to look them up and tell you which mfr it was that used that one.
rh
The Following User Says Thank You to Robert Haus For This Post:
Old 03-31-2008, 09:53:47 AM
vern0n vern0n is offline
Looks pretty rare whith that hopper opening and the main caps on the back side of the frame. I have seen one other engine with this style mains, (I don't remember the hopper), and no one knows who made it either.
Old 03-31-2008, 10:02:26 PM
Ray Gardner Ray Gardner is offline
I have seen a 7 hp Monarch made by Nelson Bros with that exact main bearing mounting, I think you have a very special Engine.
Ray.
Old 04-01-2008, 09:49:34 AM
John Merry John Merry is offline
I have seen 2 other engines including the one Ray mentioned with the crankshaft and flywheels hanging out past the base with the bearing caps taking the force of ignition, not to mention the shear force of the flywheel crankshaft weight. It looks like a weak design (but great for a collector) My theory is, the first few engines made had a name tag but after the engines started self-destructing from the design flaw, that they quit putting their name on it so it would be hard to find the maker to complain.
Old 04-03-2008, 12:54:18 AM
Les Layton Les Layton is offline
David Brown brings a Monarch to Powerland quite often that is built this way. I took several pictures but cannot find the at this moment. Seems his also has a strange hopper. Les
The Following User Says Thank You to Les Layton For This Post:
What kind of engine is this? Steve H Antique Gas Engine Discussion 7 04-15-2012 10:40:19 PM
What kind of engine is this? mshane Antique Gas Engine Discussion 3 03-16-2008 04:55:45 PM
What kind of engine? Emma Steam Stationary Engines, Traction Engines, Steam Boats 7 01-29-2008 10:38:37 PM
What kind of engine? Jim Sherman Antique Engine Archives 7 04-02-2004 05:47:09 PM
What Kind of Engine is This? Steve Barr Antique Engine Archives 0 10-18-2000 11:47:50 AM
