Fairbanks Morse ZC-118 - How to start
this thread has 2 replies and has been viewed 452 times
Old 07-02-2019, 04:30:13 PM
PsRumors PsRumors is offline
Default Fairbanks Morse ZC-118 - How to start
I found a ZC 118 that has been sitting a few years. It isn't stuck and has spark. What needs to be checked prior to adding gas and then what are the proper starting procedures?
Old 07-03-2019, 10:26:21 AM
AKMark AKMark is offline
Default Re: Fairbanks Morse ZC-118 - How to start
Oil the valves and rocker arm. You might want to change the crankcase oil. Check that there is Water / antifreeze in the tank. Put fuel in it and it should run. I'm not sure about the fuel system on it, I have a Z 739 and it has a primer to start it.
Old 07-04-2019, 03:09:45 PM
dkamp dkamp is offline
eMail NOT Working
As Mark said- OIL the valves... particularly the intake, as it's vacuum-operated. I hit mine with penetrant, then tap on it with a dowel and leather mallet a dozen times, to make sure it's really moving free... it should be fingertip-operational.
Make sure the crankcase isn't half-full of water... a fresh round of oil is not a bad idea. Make sure the exhaust isn't full of wasp nest, and that the magneto clacks just past TDC with a scary-hot spark. Clean the plug, spray the inside of the cylinders with some light penetrant and roll it over a dozen times with the plug out while you watch that spark plug crackle at each snap of the impulser.
Reinstall the plug. When I start mine, I hold open the exhaust valve and spin it up to speed, then let go of the crank and exhaust valve, and it fires right up. If you turn the flywheel without the crank, do NOT put your hands any place but on the RIM of the flywheel. Put your hand on those spokes, it'll pull you right in and break your arm, fingers, head... anything that gets too close. Remember- it's a big cylinder, and a long stroke.
10 hp Fairbanks Morse Z Won’t Start Martin in Ca. Hit & Miss Gas Engine Discussion 10 01-19-2018 09:55:03 PM
Fairbanks Morse 3HP Z Won't start ColvilleJeff Hit & Miss Gas Engine Discussion 10 07-13-2016 06:10:39 PM
Electric start Fairbanks Morse 6 HP SteveK Hit & Miss Gas Engine Discussion 10 12-27-2015 04:47:18 PM
Fairbanks Morse Y Style H Air Start huberman Vintage Diesel and Oil Stationary Engines 1 09-03-2013 03:01:04 PM
Fairbanks Morse Match start Tom Weatherford Hit & Miss Gas Engine Discussion 7 04-04-2008 02:19:13 PM
