Leroi Q185D Compressor Rebuild
this thread has 1 replies and has been viewed 177 times
Old 09-03-2019, 12:39:46 PM
Stephenw Stephenw is offline
Default Leroi Q185D Compressor Rebuild
First post here.
Long story short.
I wanted to rent oilfield equipment. Went out and bought a 1988 Leroi Q185D Towable Air Compressor online that was "ready to work"
Engine was leaking coolant through liners, two bad injectors, two rings broken, and every piston was scored. I set it aside to tinker with in my garage and bought newer equipment and took it as a loss. Over about a year and half I eventually got the engine done and runs like a top.
I do not have a parts manual and need some parts for the unloader valve now. Is there anyone here that can help me with this? I can not find the right manual on ebay even.
Attached is some pictures of the engine rebuild. Waukasha VRD220 now owned by Arrow.
ID:	342952   Click image for larger version
ID:	342953   Click image for larger version
ID:	342954   Click image for larger version
The Following 2 Users Say Thank You to Stephenw For This Post:
Old 09-10-2019, 10:34:50 PM
Default Re: Leroi Q185D Compressor Rebuild
Humm ready to work..... hope their tongue and fingers fall off ....
anyway nice work , I wonder if you look at a sullair or IR 185 , at that end "the compressor" not too much different as for unloaders and governor controls , PM me and I can get a pic of my Sullair 185 unloader
Leroi Dresser 600 compressor stalling. dankawasaki Machine Shop and Tool Talk 22 04-21-2016 10:41:45 AM
1949 LeRoi Gas G1 125 CFM Compressor (looking for parts) nmathews Vintage Construction Equipment 0 02-03-2016 09:30:51 PM
Airmaster Compressor = LeRoi 4 cyl Head Needed CommandoTom Multi-Cylinder Stationary Gasoline Engines and Power Units 4 07-16-2013 10:52:55 AM
Leroi 210 compressor mrautocar Multi-Cylinder Stationary Gasoline Engines and Power Units 2 04-02-2012 01:34:14 AM
LeRoi combination Compressor/Diesel Lyndon Strother Multi-Cylinder Stationary Gasoline Engines and Power Units 1 12-28-2009 12:03:55 AM
