Reid 12hp - My new project
this thread has 14 replies and has been viewed 758 times
Old 10-05-2019, 11:15:40 PM
Alco112 Alco112 is offline
Photo Reid 12hp - My new project
Here is my new Reid project. I didn't know much about these engines before getting it, but have enjoyed reading up on the forums about this engine. I have always wanted a nice size engine and this looks like it will be a fun project.
Still going through the pile of parts that were with it. Looks like most of the parts are here with a few exceptions. Lots of repairs needed... Cracks and bent main rod at the crank mount end. some of the valve body flanges are missing corners etc. Nothing too bad. Looks like somebody grabbed the builders plaque off of the base recently just before the auction based on the recently expost paint/rust. Can't read the serial stamped on the cyl boss. hopefully I can find one on the crank or other common locations.
The water jacket at the cyl end is the worst. Looks like it was sitting upside down in the mud or creek for years. The end is pretty thin and has has some braze where somebody attempted to start repairs. That is the only place that has any deep erosion. Looking closer it looks like there might have been an end cover instead of just the small washout covers? searching for similar photos to verify.
Starting the 1st electrolysis bucket tonight on the charging piston. Many more buckets to follow..
ID:	345803 Click image for larger version
ID:	345801 Click image for larger version
The Following 5 Users Say Thank You to Alco112 For This Post:
Old 10-06-2019, 06:36:59 AM
Default Re: Reid 12hp - My new project
Good luck with your project ! Do you know what year and HP it is?
Old 10-06-2019, 08:59:21 AM
The 12hp Reid engines used the small oval hand hole covers on the end of the cylinder. Much of the erosion is likely from the hot tube burner. The chimney was either burned out in the back or totally missing allowing the burner flame to hit the cylinder casting. The constant blasting from the open gas flame is very erosive. A lot of engines saw many decades of hard service. Proper care and maintenance was often lacking especially as oil production fell and people did only what they needed to do to get by.
You'll have a nice engine when it's done.
The Following 2 Users Say Thank You to Kirk Taylor For This Post:
Old 10-06-2019, 09:54:22 AM
OrgWayne OrgWayne is offline
Alco , did U get that at Shurmans Iron Ranch ? maybe not spelled right , U might get some more info from Antique Powerland in Brooks Or, I have seen a few there during the Steam Show
Wayne
The Following User Says Thank You to OrgWayne For This Post:
Old 10-06-2019, 10:03:34 AM
Hi,
Yes this came from Schurman's auction. Nice to know there are some local at Brooks. I havent been down there for years. Usually have a conflicting event that week of the show.
It makes sense that the hot tube could have caused the jacket erosion.
It is for sure a 12hp based on the flywheel diameter. Still havent located a serial number yet to determine the year yet.
Thanks!
The Following User Says Thank You to Alco112 For This Post:
Old 10-06-2019, 03:36:31 PM
Tom Geier's Avatar
Tom Geier Tom Geier is offline
From Newport Ohio?
Sorry. Different one
Old 10-06-2019, 06:35:36 PM
Photo Re: Reid 12hp - My new project
Rust slowly bubbling off. 1st signs of clean metal starting to appear after 24 hours
Progress after 48 hours
Old 10-07-2019, 12:34:49 PM
Keven Withers's Avatar
Keven Withers Keven Withers is offline
Does that engine have the correct main bearing caps?
Old 10-07-2019, 08:42:08 PM
Both main bearing caps and the connecting rod end bearing assembly are missing.
I think I have all the valve assemblies, except the pressure relief valve for the charge cyl.
Governor is missing, but I will be able run unloaded easy enough without it.
Old 10-07-2019, 11:13:43 PM
Nice,
please keep us updated with progress and pictures
Old 10-12-2019, 07:50:22 PM
Going through the bucket of parts to see what all I'm missing. Looks like I have one homemade fabricated crank bearing cap.
Missing a few of the bearing brasses so will have a few fun things to machine up.
Trying to figure out why the main piston has a hole in the top end. There is a piece of steel rod sticking out with a flared end inside so the rod is captured between the piston top and the wrist pin. Not sure what they were up to...
Old 10-12-2019, 07:51:32 PM
I thought both were missing, but I did just find one fabricated cap. But both of the original cast ones are missing. As well as a few of the rod ends.
Old 10-12-2019, 08:07:48 PM
Attachment 346427
Perhaps that's how they drove out a stuck piston. It wouldn't have been my first choice, but people do what they need to do.
Old 10-12-2019, 10:19:27 PM
That makes sense, since there is no head to remove for access. Only the small hole for the hot tube. They must have drilled the hole so they wouldn't risk cracking the piston with the small area of the shaft.
Must have been stuck pretty good based on how the end of the shaft inside the piston is flared out...
Old 10-14-2019, 10:03:41 PM
Or at some point the piston was pushed in too far and the 1st ring popped open past the bore into the slightly larger combustion area. They then drove the piston back to break the ring. Be careful going back together so this doesn't happen to you. There are better ways to overcome that problem as well.
Bill Klein
How common is a 12hp Reid Jebaroni Oil Field Engines & Related Equipment 10 04-07-2013 07:20:39 PM
12hp Reid Valve Skidmore Oil Field Engines & Related Equipment 7 04-03-2011 11:18:27 PM
12hp reid value Rich Hudak Oil Field Engines & Related Equipment 0 03-11-2007 05:55:49 PM
Our New Toy, 12hp Right hand Reid zach williams Antique Engine Archives 0 07-19-2004 07:46:45 PM
MOUNTING OC MAG ON 12HP REID Tom Weatherford Antique Engine Archives 2 03-21-2002 11:55:58 PM
