1 1/2 H.P. Maynard Gas Engine
this thread has 5 replies and has been viewed 1629 times
Old 07-22-2015, 06:18:36 PM
David Fassett David Fassett is offline
Default 1 1/2 H.P. Maynard Gas Engine
I just aquired a11/2 Maynard gas engine
serial #12046
THE TAG READS Charles William Store
New York City
New York
Need information
where it was made
Any Information appreciated
Thank You
David Fassett
Old 07-22-2015, 08:52:09 PM
Doug Kimball's Avatar
Images: 78
Default Re: 1 1/2 H.P. Maynard Gas Engine
david,
Need a photo to determine if Nelson Bros. or Jacobson manufactured.
In Kennebunk, Maine;
Doug Kimball
Old 07-22-2015, 09:14:43 PM
John Savot John Savot is offline
Is there any letters before the number that should also be on the r/h flywheel? What is the ignition source? Is the hopper sides vertical or tapered? There is no known records to reflect the year of manfacture if it is a Nelson Bros. which I believe it is. The ignition source could date it within a few years.
John
Old 07-22-2015, 09:20:26 PM
Heavy Metal Heavy Metal is offline
If you can't post a picture then tell us what casting numbers or letters you see. The Nelson's had raised casting ID's in several spots like the the head, connecting rod, base, and flywheels. If it has a Webster mag the number off the bottom of the bracket could also help.
Here are pictures of my Nelson Brothers, does it look similar?
Old 07-22-2015, 09:47:36 PM
Blackbeard Blackbeard is offline
This is my maynard made by nelson bros.
Old 07-23-2015, 05:57:32 PM
Odin Odin is offline
Very nearly all of the Nelson Brothers records were burned when it became apparent that there was not a demand for spare parts for the machines after having gone through a couple of owners.
Most of the surviving engines can be identified as a Nelson Brothers built engine by the shape of their flywheels and hopper, as the Nelson built engines have a rather distinct style with few variations across several different tags and brands of engine.
The first maynard picture is the older style Nelson built, which off the top of my head was common around 1915.
Blackbeard's Maynard is the later style, using a Wico type EK magneto that was popular around 1926.
I have a Little Jumbo built by Nelson Brothers that is very similar to Blackbeard's Maynard, but has the straight-walled hopper instead of the slanted wall hopper.
Best thing to do is post pictures of your engine, or better make a video overview of it showing what you have from several angles to post. Unless you happened on something really unusual, it'll almost certainly be identified quickly based on what the people here know about Maynard-badged engines.
The Following User Says Thank You to Odin For This Post:
Maynard Kerosene Engine. Tell me what you know ShaneZahn Antique Gas Engine Discussion 18 12-10-2014 08:51:41 AM
Maynard 5 hp engine parts pope1033 Antique Gas Engine Discussion 2 07-29-2013 09:20:39 PM
Maynard Throttle Governed Gas Engine Tom Sampson YouTube Old Iron Videos 1 10-14-2012 07:53:40 PM
Maynard hit n miss engine shane hit n miss smiley Antique Gas Engine Discussion 1 08-08-2012 11:38:59 AM
Maynard hit n miss engine shane hit n miss smiley Antique Gas Engine Discussion 4 08-07-2012 10:24:01 PM
