Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engine Collectibles
Model 82 Flywheel
this thread has 1 replies and has been viewed 788 times
Old 10-04-2017, 06:17:40 PM
willsmith123 willsmith123 is offline
Default Model 82 Flywheel
Can anyone assist with any tricks to get the flywheel off an 82? I have tried some light smacking and prying, with no luck yet..
Thank you for any help !
Old 10-04-2017, 07:01:35 PM
Exclamation Re: Model 82 Flywheel
Cut two 2x4 pieces about a foot long. Make sure they are equal in length. Remove the flywheel nut and then install on the crank BACKWARDS, so the flat side is FLUSH or slightly above the end of the crank. Stand the boards on end and place the flywheel rim on the standing lengths, on opposite sides. Place a piece of brass or aluminum plate at least 2" square on top of the nut and give a sharp rap with a small steel mallet (3 pounder will work fine). Don't whale on it, just a foot or so of drop should do. Try to hit the brass or aluminum as square as possible. The vibration and engine weight should pop the flywheel loose. This has worked for me on both the 82 and 92 engines.
Hercules 6hp model SK flywheel Adam Jones Smokstak Down Under 0 10-21-2015 06:54:28 PM
Model ZZ flywheel Johnnyboy Small Air Cooled Gasoline Engines 4 05-26-2013 06:26:36 PM
Model engine flywheel 16GaarScott Steam Stationary Engines, Traction Engines, Steam Boats 0 06-06-2011 12:11:58 AM
Flywheel Starting a Model 72 Ultrasport Maytag Engine Collectibles 2 02-05-2011 03:15:28 PM
Help to get flywheel off Model 92 Malcolm M Maytag Engine Collectibles 9 09-05-2010 01:52:20 AM
