Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engine Collectibles
Maytag Coil?
this thread has 2 replies and has been viewed 1307 times
Old 10-08-2017, 02:19:31 PM
shiftlessguy shiftlessguy is offline
Default Maytag Coil?
On all or most of model 92's did the high tension lead go thru mag plate
Old 10-08-2017, 03:33:47 PM
turbo turbo is offline
Default Re: mayrag coil ?
Yes they did
Old 10-31-2017, 04:16:32 PM
Exclamation Re: Maytag Coil?
The coil has a recession where the coil output wire fits to the mag. There should be a small tin cap, held by 2 screws, with a rubber boot underneath. The boot seals out moisture and also holds the wire in place. Over the years I have found that there are actually 2 different tin caps - the mounting hole spacing is slightly different between the two.
Maytag D & DA coil Andrew Mackey Maytag Engine Collectibles 9 01-21-2013 12:31:15 PM
Maytag 82 Coil BobGrif Maytag Engine Collectibles 0 02-01-2011 06:37:37 PM
Maytag 72 coil Frank Timmermeier Maytag Engine Collectibles 4 02-17-2008 04:19:48 PM
maytag coil BobRR Antique Engine Archives 10 10-18-2001 06:22:22 PM
maytag coil larry harding Antique Engine Archives 6 05-20-2001 09:13:49 PM
