Steam Engines
Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Steam Stationary Engines, Traction Engines, Steam Boats
Steam Stationary Engines, Traction Engines, Steam Boats Antique steam engines, their boilers, pumps, gauges, whistles and other related things that make them run.
Avery Undermount Rocker Grates?
this thread has 6 replies and has been viewed 550 times
Old 08-18-2018, 02:34:28 PM
Question Avery Undermount Rocker Grates?
Mark, at the shop, wound up with these grates.
For all anyone knows they could be new......only a little fuzzy from lying on the ground in a shed.
We know this former customer owned an undermount but, like so many others, got scrapped during WWII...….
At any rate if someone has use for them please contact me via PM.
ID:	316532   Click image for larger version
ID:	316533   Click image for larger version
The Following User Says Thank You to Craig A For This Post:
Old 08-18-2018, 04:29:48 PM
JBoogie's Avatar
JBoogie JBoogie is offline
Images: 241
Default Re: Avery Undermount Rocker Grates?
They kinda look like Geiser-Peerless rocker grates.
The Following 2 Users Say Thank You to JBoogie For This Post:
Old 08-18-2018, 05:17:24 PM
Beth thinks they resemble Port grates too so...… ……..but the farm they came from was where the undermount was used.
Old 08-18-2018, 11:45:39 PM
JBoogie's Avatar
Images: 241
Well.....
You didn't give us any dimensions, or a legible casting number.......
And an undermount Avery previously being on the farm is just hearsay.... no mention of what size Avery btw...
I think we're doing pretty good considering.........
Old 08-19-2018, 04:09:57 PM
Beth V's Avatar
Beth V Beth V is offline
REEVES! Here is the pattern for the rocker grates in the 32.
Any idea how many companies shared the same grate pattern versus making their own?
ID:	316626   Click image for larger version
ID:	316627   Click image for larger version
ID:	316628   Click image for larger version
The Following User Says Thank You to Beth V For This Post:
Old 08-19-2018, 05:53:44 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
I'm thinking that the rocking grates were a vendor patented appliance. Many builders used them and paid a royalty?
Old 08-19-2018, 05:56:08 PM
Tom Runty Tom Runty is offline
The grates above look like the Avery rockers I have seen. Beth's Reeves rockers will work in an Advance Rumely quite nicely. I made a pattern for Dennis Christiansen's many years ago, copying it from one of Norman Grob's grates. Made a hanger pattern as well.
The Following 2 Users Say Thank You to Tom Runty For This Post:
30 or 40 hp Avery Undermount Randy Kvill Steam Stationary Engines, Traction Engines, Steam Boats 16 03-18-2018 11:12:28 AM
Avery Undermount Maier Scale Model Engineering 5 01-10-2018 03:10:00 PM
120 hp (40?) Avery undermount KPerron Steam Stationary Engines, Traction Engines, Steam Boats 16 12-04-2009 03:30:41 PM
Undermount Avery or 110 Case oldnintyseven Steam Stationary Engines, Traction Engines, Steam Boats 15 03-23-2009 10:11:44 PM
30-90 Undermount Avery Tanner Remillard Steam Stationary Engines, Traction Engines, Steam Boats 35 09-19-2005 05:36:35 PM
