How do I find all threads I started (2.5KVD spec B)
this thread has 6 replies and has been viewed 354 times
Old 08-19-2018, 02:57:56 AM
Motorhead's Avatar
Default How do I find all threads I started (2.5KVD spec B)
I am searching for any threads I have started. I looked in "Your Site setings" and I don't see where I find just the ones I started. Maybe one of the many here smarter than me can tell me.
The Control panel
and gauges of my
7.5JB
Old 08-19-2018, 03:17:59 AM
turtmaster turtmaster is offline
Default Re: How do I find all threads I started
Here it is, under your "statistics" on your "public profile" page, here is a link to the threads that you have started, https://www.smokstak.com/forum/searc...archid=8446674
Search IDs are only held in a temporary cache. You have to go for the real thing. -- Harry
The Following User Says Thank You to turtmaster For This Post:
Old 08-19-2018, 03:32:06 AM
Click on your user name at top of any subject. Click statistics tab. Second line down.
Doc
"Resistors simply aren't as sexy as Twinkies" Hackaday
The Following 2 Users Say Thank You to Thaumaturge For This Post:
Old 08-19-2018, 09:05:15 AM
Jim McIntyre's Avatar
A Google "site search" is an option to use if you're interested in finding threads you contributed to and where, say, Fram filters were mentioned.
Like this:
http://bfy.tw/JTnb
Old 08-19-2018, 12:15:15 PM
Motorhead's Avatar
You guys can ALL take today off now..... THANKS!
The Control panel
and gauges of my
7.5JB
Old 08-20-2018, 09:32:05 PM
scoops scoops is offline
I just always click on search , then advanced search.
You can choose to search on threads started by you, or threads where you responded.
Old 08-20-2018, 11:48:49 PM
Motorhead's Avatar
I needed to find the thread I started about a 2006, 2.5KVD propane fueled unit I fixed for a neighbor last year. https://www.smokstak.com/forum/showthread.php?t=173937
He called me this weekend saying that after he removed, refilled the propane tanks and replaced them, the set will just start and die in about 3-5 seconds.
So here is the rest of the story......
I went down to his place and sure enough, it started and faded out in 3-5 seconds after letting go of the start button. So I knew it was making its own electricity. Went over to the propane tanks on the camper, pulled the tank slider out and the dual regulator LP indicator on the regulator was red. I switched tanks and the set started and ran perfect. Reached in to the first tank, the one that made the regulator indicator show empty and tightened up the hand wheel on the LP pigtail that connects to the tank. Switched it back to that tank and the set ran. Easy Fix!
He is a good friend and neighbor but I wanted to tell him... "Next time you work on this RV, you will keep your HANDS in your POCKETS".
The Control panel
and gauges of my
7.5JB
The Following 3 Users Say Thank You to Motorhead For This Post:
Need Some Help on an Onan 2.5KVD Spec B. Running Rich Motorhead Onan Generators 22 12-08-2017 11:30:15 AM
Can't find wiring diagram for spec v cck made in 89 YellowLister Onan Generators 4 03-24-2017 07:10:31 AM
ONAN 2.5KVD-2089A Spec: A Won't stay running Henry Boloko Onan Generators 8 01-29-2016 01:56:06 PM
Onan Camp Power KVD 2500 / 2.5KVD-2089A: Starter install question 3535 Onan Generators 2 12-19-2015 12:00:58 PM
threads on an ST2 mdj21 Vintage Diesel and Oil Engines 2 12-24-2014 03:59:02 AM
