DJB 6.0KW DC Charging Circuit question?
this thread has 13 replies and has been viewed 3579 times
Old 06-20-2005, 05:49:59 PM
mav7771 mav7771 is offline
Default DJB 6.0KW DC Charging Circuit question?
I have come upon a "basket case" djb genny (MODEL 6DJB 3R/3435G SER#83C729909 GEN.DATA 6JB3N1B) and have managed to reassemble it to the point of getting ready to cranking it over. All the wiring looks to be right per the wiring diagrams in the onan manual. My question is about a large 3/4" dia. resistor located in the blower exhaust port of the actual generator housing that I believe to be an adjustable charge rate for the dc starting system. There is one lead comming from the back of the blower port that looks to come from the windings area with a solderless connector that looks to go to this resistor. This brown resistor includes an adjustable metal slide band located on the out side of the resistor ...I think onan# (304A500). This part mounts on a threaded rod and pressed washers (top& bottom) that is connected at the top thru the gen housing and at the bottom on a "L" bracket. All of this assy is then covered by a grill type cover.
Now comes the wiring question ...There are three screw connectors along this resistor and another one on the sliding band makes four options to connect wire lugs. There is also a 3" lead with solderless connectors on each end that I assume to be a ground that was with the other parts. I have gone over the wiring diagrams and service manuals and there is no reference to how this adjustment works or connected. Any help from you guys would be great. Thanks for looking! If picture would hel I can provide....thanks again!
Old 06-21-2005, 09:48:22 AM
ichudov ichudov is offline
Default Re: DJB 6.0KW DC Charging Circuit question?
I have some pix of my onan DJE that could be of help to you:
http://igor.chudov.com/tmp/onan/Dies...e/dscf0047.jpg
Old 06-21-2005, 12:24:46 PM
Thanks for the response....looks close to what I have.....does the lower wire lead go to ground? I only see two wires...
Old 06-21-2005, 03:17:17 PM
I think that lower wire leads to ground. Unfortunately, I cannot check it now because the generator is inside an enclosure. It can be opened up, but it is not easy.
i
Old 06-21-2005, 05:27:52 PM
thanks for your help...still not to comfortable with starting until I know for sure...don't want to fry any thing. R
Old 06-21-2005, 07:58:15 PM
ok ...update ...tried to trace back one lead comming from the back of the blower port that looks to come from the windings area with a solderless connector. Found a metal tag on this lead w/ "B1" on it. looked for the opposite end but could not locate another B1 ....did find it to have connutity to B2....once again leading me to beleive it is an adjustment to the 12 volt battery charger. Looks like the picture sent to me by "i" has two connectors one B1 and one to ground. question is which one goes where?
Old 06-21-2005, 08:59:19 PM
Jonathan Jonathan is offline
Photo Re: DJB 6.0KW DC Charging Circuit question?
MAV,
Attached is a picture of my DJE's resistor that I think you are describing. Mine is wired up this way on the outside:
A wire (B1) comes from the generator head housing and attaches to the top connector on the resistor. A second wire connects the middle connector to the bottom connector on the resistor. The resistor must be grounded via the bottom connector or by the metal holder that holds it. My schematic shows the resistor connecting to the charger winding in the generator head I assume. This wire is labeled B1 as you have noted. From the generator charger winding to the #7 position on the wiring terminal in the control box the wire is labeled the B2 wire. The opposite side of the #7 post on the wiring terminal runs to the rectifier.
Hope this helps.
Thanks for the part numbers on the oil dipstickand cap also!
Jonathan
Name:	resistor thingy.jpg
Old 06-21-2005, 09:16:40 PM
Exclamation Re: DJB 6.0KW DC Charging Circuit question?
MAV,
OK I removed the resistor to see the rear bottom connection of the wire from the middle connector. It is connected to ground. On mine it is attached to a connector that is screwed on to the bottom of the resistor by the screw that mounts the resistor into the holding bracket.
Hope that clears up any question. My manual also states the following:
"The adjustable rate resistor slide tap (in the charging circuit) is set to give approximately 2 ampere charging rate. The resistor is located in the generator air outlet. For applications requiring frequent starts, check battery specific gravity periodically and, if necessary, increase the charging rate slightly (move slide tap up). Adjust only when engine is stopped. Avoid overcharging.
If usingb a seperate automatic demand control for starting and stopping, adjust the charge rate for its maximum 4. amperes. This normally keeps the battery charged even if starts occur as often as 15 minutes apart."
Jonathan
Old 06-21-2005, 11:34:58 PM
thanks for the response...A little confused.... looking at your picture ...the top connector is B1....and the adjustable slide connector(the one with two screws) is grounded to the housing...correct? thanks
Old 06-22-2005, 07:41:30 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Circuit for charging 12Vdc is:
Ground to bottom of resistor, to slider of resistor.
top of resister to B1 Winding on Genend
Winding B2 to Terminal 7 in Control Panel
Terminal 7 to Negative side of CR11 Rectifer Diode
Positive side of CR11 Rectifier Diode to load side of Ammeter.
Adjust for 2 amps charging current on Panel Meter for Normal Running
Adjust for 4 amps charging current on Panel Meter for Frequent Starts
Schematic diagram, see Onan Control Genset Wiring Diagram # 612-4792
In Onan YD Genset Manual # 900-0184
Bruce in alaska
Battery Charging Circuit-Onan JC Geoff Morgan Onan Generators 3 10-20-2007 09:50:39 PM
Help need circuit john_bluebird Onan Generators 6 11-12-2006 09:47:11 AM
Katolight charging circuit G Dean Generators & Electric Motors General Discussion 5 11-13-2005 06:00:54 PM
DC Circuit Breakers - Use for AC J. McNugget Generators & Electric Motors General Discussion 4 02-04-2005 09:32:27 AM
Have question on charging Keith E. Antique Farm Tractors 2 12-30-2004 03:54:07 AM
