Battery Charging Circuit-Onan JC
this thread has 3 replies and has been viewed 3080 times
Old 10-19-2007, 05:24:25 PM
Geoff Morgan
Default Battery Charging Circuit-Onan JC
I ran a search on the forum before posting this, but I will be the first to admit that I'm not the sharpest knife in the drawer on any computer formats, so thanks in advance and excuse me if I missed a previous post that addresses my question. I have an early 1980's vintage Onan 12.5 KW JC with a lot of borrowed and patched in parts, etc. The battery charging circuit is missing the ammeter (0-5-0) and the diode and heat sink. There is no capacater shown on any of the circuit diagrams and so I would think it safe to say that this is a very rudimentary charging system. I have an idea of how the charging rate is adjusted by use of the taps on the big resister on the ground side of the charging circuit. My question; Can anyone provide me with a rating or a diode number for the charging circuit. I would guess a rating something about 50 volts DC and 10 amps or 500 watts, but this is a wild guess, since that seems like a lot and the little heat sink that I have seen on other Onan JC units is just an aluminum sheet 1/16" thick and about 2 inches square. The Onan replacement ammeter was not horribly expensive from Cummins, ablut $20 (and it has not arrived on the "stock" order plan, so I may be in for an ugly surprise), but they wanted $28 for the diode and went cheap, since I'm sure that it is available at any of the electronics supply houses for much less. Geoff Morgan
Old 10-19-2007, 08:25:13 PM
Raymond Raymond is offline
Default Re: Battery Charging Circuit-Onan JC
Before spending money I'd check the output of the battery charging winding. The book says it should be above 19 volts AC.
Old 10-20-2007, 03:58:43 AM
ListerDiesel's Avatar
The Onan parts lists show a single diode, 100V PIV so anything with a PIV of more than 100V and a current rating of 10A or so would be fine.
I would suggest getting hold of a device with faston tabs rather than solder tags, makes it easier to install.
For redundancy, you could buy a surplus dual-diode module, or even a 35A bridge off ebay and use that, if you ever lose the diode you'll have more there without changing anything!
35A bridges sell for a couple of $$'s, have a 5mm fixing hole and Faston tabs. The larger Semipack common cathode modules from Semikron, IR and Ixys are physically bigger and have dual-hole fixings with M5 tapped captive nuts.
For my money I'd go for the bridge, cheap and effective, won't need a heatsink if you bolt it down to the control box metalwork with a bit of heat conductive paste. If you try and get one of the metal-cased type, that would be better. Look for a KBPC35-02 or KBPC25-02, both of these are 200V PIV.
Connections:
Bridges have two ~, one + and one -. In one of the ~ and out the +
Dual-Diode modules have connections according to their configuration. Same as above, go in on one of the ~ and out of the +.
Peter
Old 10-20-2007, 09:50:39 PM
Geoff Morgan
Thanks for the information, I'll post how things work out in the future. I think that I have an old bridge unit in my tool box; I'll check and make sure that the thing is not fried. I ran the JC unit today and checking the output of the AC charging circuit with my trusty(?) "Chicago Electric" digital volt meter, I read 8.2 volts (lead B2 to ground/case). This was measured with no control circuit in place which is to say that this was the output with only residual magnetism in the armature. Considering that fact, I will predict that the charging circuit will perform well after the armature flux is brought up to snuff with the control voltage.
DJB 6.0KW DC Charging Circuit question? mav7771 Onan Generators 13 02-03-2015 02:50:37 PM
2.5 LK battery charging problem Jim Kinler Onan Generators 2 11-24-2007 03:40:37 PM
Katolight charging circuit G Dean Generators & Electric Motors General Discussion 5 11-13-2005 06:00:54 PM
Battery Charging AndyG Trucks, Trailers and Hauling for Shows 10 09-25-2005 04:27:33 PM
6.5NH Battery Charging shawnb Onan Generators 2 12-11-2004 10:08:10 PM
