Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Antique Engine Photos
Antique Engine Photos OLD gas engines, hot air engines, Diesels and steam engines. An electronic photo gallery to showcase the best of your old engine collection.
Looking for steel wheels
this thread has 5 replies and has been viewed 4697 times
Old 10-14-2010, 10:14:44 PM
Hap Perry Hap Perry is offline
Default Looking for steel wheels
I'm looking for steel wheels to build a cart for one of my engines. I would like to find 8 and 10" wheels. does anyone know ware i could find them? any help would be aprecated.
Old 10-14-2010, 11:03:43 PM
speleausmining
Default Re: looking for steel wheels
Try looking for a local warehouse or shippers supply company. They often carry replacement wheels for warehouse carts. Personally I Have used wharehouse supply companies ocasionally but my favorite source is an antique store that has a large yard packed with "junk" The yard is actually just heaps of rusty iron with barely a spare space anywhere. Best of all stuff in the yard is cheap and if you are willing to dig you can really find some decent stuff. I have goten sets of wheels at 25 bucks a pair (50 bucks for 4).
Old 10-14-2010, 11:34:36 PM
Jordan's Avatar
Jordan Jordan is offline
http://catalog.mrroller.com/viewitem...st-iron-wheels only other supplier i've found that has cast iron ones that look period other than one of the sponsors here. mark bruto in california if i'm correct.
Old 01-12-2011, 07:07:06 PM
junction 28 junction 28 is offline
Photo Re: looking for steel wheels
Hi jordan ever thought about making your own, i did when none could be sourced got right size metal heated and formed around cast wheel the right size to form rim .Drill out holes for spokes.Get peice of pipe for hub and weld larger pipe on top
10mm back in to form hub.Cut spokes longer fit and adjust to centralize hub then weld and cut off excess spokes. Every where i go people assume it is original as it is simple blacksmithing.
The Following User Says Thank You to junction 28 For This Post:
Old 01-12-2011, 08:37:59 PM
Default Re: Looking for steel wheels
Try Cattail Foundry. He has many different size wheels.
Jim
Old 01-12-2011, 08:53:54 PM
Peter Peter is offline
You can run a wanted ad on Harrys with as much detail as you can on what size you need. Od, width, bore.
I know I have some, but most everything is under 2 foot of snow now. Except maybe two sets of 4 that are probably little to a lot on the heavy side. I dont remember those eight might be 3 or 4 inches wide and 10 or 12 diameter and pretty big bore, maybe close to two inch. One set much heavier than other.
Would be hard to ship, although they might fit two per flat rate box. Might, might not fit all all or might need one box per for the heaviest. Anything for a typical 2hp cart, would be burried right now and perhaps frozen into the ground. Most likely stay that way till spring. I see a lot of wheels at engine shows. Most often you see pairs. That works ok sometimes, even if they dont match. It is not authentic, its just a convenience to move the engine.
Isnt there a big Florida show around this time of year?
There is a guy here selling IHC repro wheels that are very good quality and sized right for 2 or 3 hp engine. Don Ober?something I think. I got a set for my 3hp famous. You have to clean up the bore, they are rough cast.
I dont know what Cattail has, but they are good folks and make good castings. Although Amish, They do have a business phone. I think you generally leave a message and they call back. I would assume those would need a little finish work too. But, I dont know that.
Steel Wheels rg11x Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 19 08-03-2010 05:49:10 PM
Belting for Steel Wheels Tractasaurus Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 20 02-16-2008 02:57:25 PM
Whaddya think? (steel wheels on a steel deck) MoRo Trucks, Trailers and Hauling for Shows 10 02-15-2008 05:53:33 PM
RUBBER TO STEEL WHEELS SONNY L Antique Engine Archives 8 08-25-2003 06:11:55 PM
Steel wheels mike walden Antique Engine Archives 3 05-26-2002 07:55:28 PM
