Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Military MEP and Aircraft Gen-Sets
Hercules BXB Engine Kurz and Root Generator
this thread has 2 replies and has been viewed 376 times
Old 05-22-2019, 08:30:00 AM
russj russj is offline
Default Hercules BXB Engine Kurz and Root Generator
i help a friend that picks up scrap and found this generator and saved it its a 1945 hercules bxb with a kurz generator hand crank engine turns over but no spark i am checking the points etit was used at bluemound towers in luverne mn for ham radio i plan on getting motor running then checking out the generator will post photos
The Following 2 Users Say Thank You to russj For This Post:
Old 05-22-2019, 01:40:05 PM
Default Re: Hercules BXB Engine Kurz and Root Generator
The BXB is a good engine, also used on the John Deere LA tractors. mag parts should be readily available. That engine has the typical JD sound - badump, badump, badump etc, and the Kurz and root was a good unit too. If it sat for a while or the junkyard used a magnet to pick it up, you may have to flash the generator to get it working again.
I had one of these myself, and I used it a lot. i may have an owners manual for the engine, i will have to look thru my records.
Old 05-22-2019, 08:43:52 PM
John Schwiebert John Schwiebert is offline
John Deere LA tractors used a John Deere engine. Early model L tractors used the NX Hercules which is larger than the BXB, No BXB engines were used by Deere,
Kurz & Root Generator Scott P Generators & Electric Motors General Discussion 9 01-23-2013 01:16:07 AM
Kurz and Root generator help ctowndieselboy Military MEP and Aircraft Gen-Sets 2 07-22-2010 01:01:08 AM
Kurz&root 6.25 KVA generator JIM MODEL 110 Generators & Electric Motors General Discussion 3 07-07-2010 07:22:50 AM
Kurz & Root / Hercules Surplus Chilly Generators & Electric Motors General Discussion 6 05-14-2004 09:36:36 PM
Kurz & Root Generator Jim Bosse Generators & Electric Motors General Discussion 0 04-04-2004 11:52:38 AM
