1948 Case VAC Hard Starting
this thread has 17 replies and has been viewed 3244 times
Old 09-24-2015, 02:52:50 PM
Jordan's Avatar
Jordan Jordan is offline
Default 1948 Case VAC Hard Starting
Hi All,
Continuing to help my friend with his VAC. Its got brand new plugs, wires, points, condensor, and cap/rotor. After all those new parts its still hard to start, it is getting gas to the carb, as we can open the drain tap and gas will come out. Also its getting nice blue spark to the plugs.
Any thoughts on what to check next? Carb need an overhaul?
Thanks for any help/suggestions.
Regards,
Jordan
The Following User Says Thank You to Jordan For This Post:
Old 09-24-2015, 03:31:13 PM
ehpower2's Avatar
ehpower2 ehpower2 is offline
Default Re: 1948 Case VAC hard starting
when you try to crank it does the magneto impulse click when the motor is turning over
The Following 2 Users Say Thank You to ehpower2 For This Post:
Old 09-24-2015, 04:08:18 PM
casertractor casertractor is online now
I would surgest if you dont already have them maybe try getting a hold of the parts and operators manuals aswell as the shop manual for the VA series or just the VAC.they should give you the proper specs and yes going over the carb would not hurt.have you tried cleaning up the sediment bowl ? as it might be full of junk.John
Old 09-24-2015, 09:47:21 PM
JIMnWV's Avatar
JIMnWV JIMnWV is offline
eMail NOT Working
Will it start if you choke it each time? Just thinking about the valves and intake gasket. Also check the carb / intake gasket, and make sure it's gas and not water coming out of the carb bowl, seen that before too. Timing been messed with? Check the little things, mainly the carb.
The Following 2 Users Say Thank You to JIMnWV For This Post:
Old 09-24-2015, 11:40:12 PM
Jordan's Avatar
ehpower2, this particular VAC is has distributor ignition.
casertractor (John), This tractor has been in my friends family since new, and he still has the original documentation that came with the tractor when purchased. I will look into the shop manual for the VA Series. Will look at the sediment bowl next time i'm near the tractor.
JIMnWV, no it won't start each time if its choked. Especially after it has run and we try to restart it. It was like this before we put all the new ignition parts on it. Will look at the carb/intake gasket next time I'm near the tractor. As far as I know the tractor has not had any major engine work done to it, so the timing should be as set from factory.
Thanks Guys for all the great help and suggestions so far,
Regards,
Jordan
Old 09-25-2015, 05:55:05 AM
JIMnWV's Avatar
eMail NOT Working
Next time your close to it pull the distributor cap off and wiggle the distributor shaft, any loose motion? Next time you have it running take a piece of paper size of a dollar and lay on top of the exhaust, hold on to it and watch it. It will flutter but if it tries to go down the exhaust you have exhaust valves not sealing properly. That's how I found the miss in my wife's VAI. Make sure adjustments on carb have not been altered too. Good luck.
Old 09-25-2015, 09:38:17 AM
Jordan's Avatar
Thanks Jim. I will check the things you suggested next time i'm over at my friends and near the tractor. If the exhaust valves do turn out to not be sealing properly, does the head have to come off to do a valve job in order to fix that?
Thanks Again,
Regards,
Jordan
Old 09-25-2015, 10:42:10 AM
Gene Williams Gene Williams is offline
Even though it has a nice blue spark, maybe try a different coil just to make sure yours is OK. Sometimes electrical issues can mimic fuels problems.
The Following 2 Users Say Thank You to Gene Williams For This Post:
Old 09-25-2015, 02:32:56 PM
THIS........
Ignition and carburetor symptoms are identical.......
You have to rule one out to get to the bottom of things.......
The Following 3 Users Say Thank You to Craig A For This Post:
Old 09-25-2015, 02:52:17 PM
Jordan's Avatar
Thanks Craig and Gene,
Will add that to the list to check. I forgot mention in my original post but along with the other ignition parts the coil was changed with a brand new one. Still will check it out.
Thanks Again Guys for all the Great help! Hopefully we can get this licked, as this is one of my friends primary tractors that he uses.
Jordan
Old 10-01-2015, 03:23:56 PM
Has their been any progress made with this tractor ?.John
Old 10-02-2015, 09:39:36 AM
Jordan's Avatar
Good Morning John,
No progress yet. Going up to visit my friend this weekend , and we'll see what we can come up with.
Regards,
Jordan
Old 10-02-2015, 01:55:43 PM
Originally Posted by Jordan View Post
Good Morning John,
Regards,
Jordan
I would say it has to be down to eather a fuel or electrical problem but you may need to go thru both to find the exact problem.what kind of system are you running 6 or 12 volt ? that might be your problem too also past owners might have altered the electrical system wich may cause it not to work/run properly and that also goes for the generator and distributor aswell as the coil.Hopefully you guys can find a solution and have this tractor back up and running soon.John
Old 10-02-2015, 02:57:39 PM
Jordan's Avatar
Tractor has the original 6 volt electrical system and is still wired the way it left the Case factory. Coil is a new 6 volt coil, cap, rotor, points/condensor, plugs and wires have all been replaced with new. This is why we are baffled, its got all these new parts and we are having this issue.
My friend is leaning towards it being a fuel issue so we are going to try and find some numbers on the carb and see if we can get an overhaul kit for it.
Jordan
Old 10-30-2015, 09:36:35 AM
Jordan's Avatar
Default Re: 1948 Case VAC Hard Starting
Hi Guys,
Just a quick update, i'm currently in the process of overhauling the carburetor, a Marvel Schebler TSX series, and will hopefully have a chance to put it back on the tractor in the next week or so. Will let you all know how it goes.
Thanks Again for all the help,
Jordan
Old 10-31-2015, 12:11:30 AM
Oldtech Oldtech is offline
Remember you need 3 things for the engine to run: Fuel, Spark, and compression. So... How's the compression?
Old 11-02-2015, 03:49:49 PM
Jordan's Avatar
Oldtech,
Compression is good. As for the actual compression numbers per cylinder not sure, as we never hooked a gauge up to it to see.
Jordan
Old 12-20-2015, 08:37:16 PM
Jordan's Avatar
An update,
Got the rebuilt Carb back on 2 weeks ago, and had the chance to adjust it last week after replacing the fuel line. Tractor starts and idles nice, and now restarts easily after shutting down. Hopefully we've got it licked now.
Now we are just waiting for a bit warmer weather to get it out and get it working so we can adjust the power screw properly.
Jordan
Hard Starting 4675-2 bcoma Generac Generators (SEARS, etc.) 7 01-17-2013 08:34:17 AM
Hard Starting Kohler K-90 Tom Jamboretz Small Air Cooled Gasoline Engines 5 05-12-2011 07:47:15 PM
Very Hard Starting Tec H60 Arbutus Small Air Cooled Gasoline Engines 14 01-09-2008 01:47:47 AM
hard starting f-20 Alan in KY Antique Farm Tractors 4 03-08-2006 08:14:41 PM
hard starting stover ct-2 brian Antique Engine Archives 1 12-04-1999 08:33:02 PM
