Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Air Compressors
Air Compressors Restoration, Repair and use of Shop and Industrial Air Compressors
Air Compressors
1920s Hobart Bros. 2 Cyl Air Compressor
this thread has 4 replies and has been viewed 1326 times
Old 04-22-2017, 10:10:31 AM
Nevr-Enuf-Stuf's Avatar
Nevr-Enuf-Stuf Nevr-Enuf-Stuf is offline
Photo 1920s Hobart Bros. 2 Cyl Air Compressor
Picked this up yesterday, never seen a setup like this where the compressor pump was part of the motor. It works good. It is missing its original control box. I havnt been able to really find any info on these compressors.
Patrick
ID:	280607   Click image for larger version
ID:	280608   Click image for larger version
ID:	280609   Click image for larger version
The Following 3 Users Say Thank You to Nevr-Enuf-Stuf For This Post:
Old 04-22-2017, 11:49:59 AM
Vanman Vanman is offline
Default Re: 1920s Hobart Bros. 2 Cyl Air Compressor
Nice! Six pole motor is cool, should be pleasant to listen to. Test the safety valve, and Hydro-test the tank to 1-1/2 times it's pressure setting before running it and letting it build much pressure.
Worthington built direct drive motor-compressor units, some of them quite large. Many of the single phase units used Wagner repulsion start motors. Very cool.
Keith
Old 04-22-2017, 02:41:19 PM
K-Tron K-Tron is offline
That is really neat! I have never seen a compressor like that before. Judging by the motor the compressor is at most 5 cubic feet per minute in capacity. Probably around 4cfm. Very very nice. You certainly do not see 6 pole 1200rpm motors very often.
Chris
The Following User Says Thank You to K-Tron For This Post:
Old 04-23-2017, 02:14:44 PM
The easy to change brushes and the oil level site glass. There are notches on the brackets to adjust the spring tension on the brushes.
Patrick
ID:	280732   Click image for larger version
Old 07-22-2017, 11:13:24 PM
Nranderson Nranderson is offline
Great compressor. I have just the one (Brunner Model 939) that after years of saying I'm going to, I'm restoring it. I'm hooked on these old tanks. I've collected a lot of things I have to control myself!
1920s Wall (Quincy) Air Compressor Nevr-Enuf-Stuf Farm Antiques and Collectibles 11 12-22-2015 10:10:36 PM
When It Rains It Pours, Another 1920s Air Compressor Nevr-Enuf-Stuf Farm Antiques and Collectibles 6 12-19-2015 09:16:11 PM
Help with Hobart Bros welder ID jimboston Welding Shop 3 07-15-2008 07:44:10 PM
Hobart Bros M5 Chris B. Generators & Electric Motors General Discussion 2 10-29-2003 07:43:10 PM
42 Hobart Bros M5 Chris B. Generators & Electric Motors General Discussion 2 03-18-2003 07:52:56 AM
