Local Auction 8 Miles from my Place
this thread has 3 replies and has been viewed 918 times
Old 10-16-2019, 09:56:29 AM
Russ Hamm's Avatar
Default Local Auction 8 Miles from my Place
Last Saturday there was an auction 8 miles from my place, I knew the seller years ago and knew he had some old International tractors. I have had the gout really bad for a little over two months now, on and off, so getting around that day was sketchy. I did have to work a little bit that morning, called the auctioneer and he said tractors would probably sell around 1pm. I supervised at work, but was on crutches at the time, clocked out at 11 and went home. Came out to the sale at 12;45, left at 2 as I had to go to my wife's class reunion...…….she actually had no idea I was cooking up a plan to go to an auction otherwise I think I would have been scolded severely.
Scrap prices here are around 25/ton. As I came late my bid number was 204. When they started on the first F-20 I was caught off guard, as I have plenty of them I really wasn't looking for another, it was stuck and went for 175 dollars. The second tractor was advertised as an F-20, unstuck, but was actually an F-30. It went for 150 dollars, later I kicked my self as I was there for the steel wheeled F-12 and 10-20. I bought the 10-20 for 250 dollars, it actually came with loose side curtains, unstuck, narrowed fenders and bad kingpins. I think it will make a good tractor. Next was a W-30 I missed, then came the F-12 which I really didn't need other than the wheels and it was unstuck. It went for 400 dollars to a family member, if I knew he was family I wouldn't have bid him up.
After the tractors there was a pile of rear lugs for the F-12 I bought for 55 dollars as the new owner of the tractor wasn't interested. And the correct manifold for the 10-20 was laying there which I got for 15 dollars choice item bid.
Anyway, these low scrap prices I think are making it a buyers market and unfortunately bad times for the seller on these McCormick models. Restored or running tractors seem to be holding their own, but these non-running or parts units are back to the prices we used to pay when we were buying them up.
ID:	346691   Click image for larger version
ID:	346692   Click image for larger version
ID:	346693   Click image for larger version
Old 10-16-2019, 05:49:12 PM
Steve Kunz's Avatar
Default Re: Local Auction 8 Miles from my Place
Congratulations, you can't beat the price and close to home on top of it! That does not happen every day.
Steve Kunz
The Following User Says Thank You to Steve Kunz For This Post:
Old 10-17-2019, 11:05:54 AM
Russ Hamm's Avatar
That's for sure. Several weeks before that I drove 2 1/2 hours one way to a huge auction with similar items plus way more and spent the whole day there going home with 35 dollars worth of parts. This auction I spent no more than an hour and a half at and 8 miles away, still hard to believe. Was able to work three hours in the morning and made it ten minutes late to the wife's class reunion.
The Following 2 Users Say Thank You to Russ Hamm For This Post:
Old 10-17-2019, 02:03:55 PM
AngrySailor AngrySailor is offline
Bought “junk” tractors AND late to wife’s class reunion... maybe you could hang a tarp between two of those “junk” tractors for some shelter?
The Following User Says Thank You to AngrySailor For This Post:
auction miles iowa GW Eddy Hit & Miss Gas Engine Discussion 2 11-07-2012 09:43:43 AM
Briggs FH in local auction Jim Thistle Small Air Cooled Gasoline Engines 1 09-26-2010 10:31:06 PM
Local auction results Jim Thistle Live Auctions of Engines, Tractors and Old Iron 2 03-30-2008 09:25:49 AM
local auction results David Greenwalt Live Auctions of Engines, Tractors and Old Iron 2 09-11-2005 08:20:55 AM
Local Auction Result Andrew Albrecht Antique Engine Archives 3 10-22-2004 09:14:07 PM
