Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel and Oil Stationary Engines
Vintage Diesel and Oil Stationary Engines Fairbanks Morse, Lister, Petter, Witte and other pump injected Diesel oil engines.
Stewart and Stevenson - Help Identifying Generator
this thread has 27 replies and has been viewed 2372 times
Old 03-24-2017, 11:50:22 PM
cnr0616 cnr0616 is offline
Default Stewart and Stevenson - Help Identifying Generator
Can anyone provide some information about this generator. How much would this weigh? Any tricks to moving a generator without a forklift?
https://imgur.com/gallery/DrzRC
Old 03-24-2017, 11:57:34 PM
K-Tron K-Tron is online now
Default Re: Stewart and Stevenson - Help Identifying Generator
Looks like a 2-53 GM diesel and perhaps a 20KW 1800rpm generator head? I would guess that it weighs around 2500lbs setup like that on the skid it is on. Perhaps weld a few tabs on the corners and use a jack to lift the generator up. Once you can get a few pipes underneath you can roll it without too much trouble. Do you have to move it very far, or lift it? Some rollers, timbers and maybe a pallet jack will help you out greatly. A come along to winch it up an incline on some timbers would be a good idea.
Chris
Old 03-25-2017, 12:06:10 AM
17kw 3phase 60cy 120-208v 17kw 59amps is what I can read. It's actually resting on about 3 to 4 ft high stack of cinder blocks. Way more lbs than I was hoping for.
Old 03-25-2017, 07:53:25 AM
Grigg Grigg is offline
Sounds like it's about high enough to back a pickup truck up to it and with a pry bar, couple planks, and few pieces of pipe roll it into the bed.
I like Chris's weight estimation, I have and have moved several 2-53 generators.
What's the rest of the story?
Old 03-25-2017, 09:55:25 AM
I would sure like to have it.
Things to remember-
If it starts to fall, get out of the way and let it do so.
It is easy to injure or lose a finger when you are lifting and shimming with a pry bar.
Old 03-25-2017, 11:23:14 AM
G.M.Johnson G.M.Johnson is offline
If I had to move that guy I would round up 4 automotive floor Jack's, knock out the corner blocks and use the floor Jack's to raise it up enough to get all the blocks out from under it. The lower it down on some 2" or 3" pipes, or you could use some wood timbers if they are pretty round. Then use a chainfall, come along, a winch, or even your truck to pull it. It will move nicely on a set of pipes. Use your truck to anchor the chainfall if needed. I would not try to load it into the back of a pickup, it's too high to winch up into. Try use a utility trailer or car hauler with a good set ramps which is lower and you will also have a place where you can attach the winch to, to get the unit pulled up onto the trailer. If needed lay down a couple pieces of plywood over the ramp surfaces to make it easier to roll across them. I've moved a quite a few pieces of machinery and this way works pretty good. If the framework had beveled edges you could probably just drag along the ground, but the way it is it will want to dig in. Just another idea.
The Following User Says Thank You to G.M.Johnson For This Post:
Old 03-25-2017, 11:41:16 AM
The Diesel Doctor The Diesel Doctor is offline
Its a 2-53. Looks like it is operational. In addition to making power it also produces a few decibels at speed. AL
Old 03-25-2017, 03:34:45 PM
Someone asked for the story behind it. My late grandfather was a commercial fisherman and this generator is located at his home for use during hurricanes. I am not sure if it was removed from one of his boats or purchased specifically for home use. Below is a link to some of the boats. The first picture was taken in Fort Lauderdale, FL where he purchased a boat and carried it back to North Carolina.
http://imgur.com/a/f1z3I
As I understand it, the generator was brought in on the back of a towtruck and then placed on the blocks.
Old 03-25-2017, 09:50:02 PM
David C David C is offline
It is an old one. It has been a few decades since I have seen a phone number listed like the one on the name plate.
Old 03-25-2017, 10:19:27 PM
I like oldstuff I like oldstuff is online now
^ Yeah, like early 60's.
Old 03-25-2017, 10:45:05 PM
Thanks for the boat pictures and background. Neat seeing the old car in the boat. Did he drive the car down to FL and the boat home?
Numerous ways to move something heavy and even more opinions...
Main thing is take it slow and easy and stop to reevaluate, or don't even start, if you're not comfortable with it.
What's your plan for the generator?
Grigg
Old 04-01-2017, 09:37:00 AM
dkamp dkamp is offline
eMail NOT Working
S&S marketed substantially towards the marine market. Since this one has a radiator, it was not set up for marine applications (they're cooled by heat exchanger via seawater)... but they're popular in the seaside markets none the less.
And yes, it's extremely efficient at turning diesel fuel into noise...
But a great generator... I'd take it!!!
Old 04-01-2017, 06:12:56 PM
Vanman Vanman is offline
Noise?? No.... MUSIC!
Though certainly the three's, sixes, and twelves are much more musical than are the two's, fours, and eights.
Old 04-01-2017, 06:51:34 PM
I think a Detroit Diesel 3-53 is the loudest engine per horsepower that I know of.
Old 04-02-2017, 11:57:25 AM
Give me the serial # and i can tell you the year it was made.
Old 04-02-2017, 01:19:30 PM
I would guess close to 3000 pounds and also it's WAAAAAAAYYYYYYYY too heavy for anything short of a 1 ton pickup. I hauled a 2-71 railroad set in my 3/4 ton, supposedly they weigh 2200 pounds, and it was kinda scary. If you try this in a 1/2 ton truck you'll damage something and you be lucky if it's only the truck.
Old 04-03-2017, 07:25:28 AM
The 2-71 is heavier.
I've hauled a 2-53 generator like this in the back of a 3/4 ton and it fit real nice and not anywhere close to overloaded.
Also hauled a 4-53 generator in bed of same truck and that was a load...
Old 04-03-2017, 05:26:50 PM
The generator was successfully moved with a forklift and a trailer. Thank you for the advice. Does the tank need to be mounted under the generator? Is a bank of batteries required to start the generator? How would I determine the CCA?
The overall goal is to connect it to the house for outages. It would be nice to convert to single phase.
Old 04-04-2017, 07:06:19 AM
Fuel tank can be most anywhere you want, just not real far below the engine so pump doesn't have to work real hard to lift it.
One Group 31 battery would be perfect, assuming 12V, or two of them for 24V.
You need to see how many leads come out of generator, at the generator.
If a whole bunch it is likely you can reconfigure for single phase only. If only 3 or 6 leads (or?) it is probably 3 phase only. A generator/motor shop can be helpful here if you don't have any literature for the generator.
Unless your house has unusually high electrical loads you can just use 2 leads of the three for your single phase needs. This makes the generator unbalanced and you only can pull 2/3 or little less of the name plate KVA. Not ideal but workable if your not taxing the generator heavily. I'm running my house on a 2-53 generator, loading single phase on 3 phase generator, plan to have it rewired for single phase only eventually, in my case requires digging into the windings to reconnect... or a full rewind.
Grigg
Old 04-04-2017, 10:51:42 AM
When I removed it from the previous electrical panel it was wired as you suggested with two leads for single phase.
Is there a recommended procedure for starting a generator like this that has been sitting up several years? Replace fuel filter, air filter, oil, etc?
Stewart & Stevenson tm-4600 conversion from 3 phase possibilities farmerfred Military MEP and Aircraft Gen-Sets 2 01-28-2017 10:13:42 PM
Stevenson & Co. Box Corn Sheller Oilpullman Farm Antiques and Collectibles 1 07-31-2014 08:49:09 AM
Stevenson Links Rob Bryce Steam Stationary Engines, Traction Engines 4 12-21-2012 12:54:13 AM
William Stevenson Found conrod Hit & Miss Gas Engine Discussion 10 07-18-2012 03:41:26 PM
-OT-Looking for Bill Stevenson, PA. Doug Barbee Hit & Miss Gas Engine Discussion 2 11-20-2005 02:22:32 PM
