Onan 6.5 NH Running Badly
this thread has 20 replies and has been viewed 1445 times
Old 05-06-2015, 08:24:23 PM
David C David C is offline
Default Re: Onan 6.5 NH Running Badly
It sounds like an ignition problem more than a fuel problem. I would take a spare condenser to the camp with you. I recently had a CCK that had been running for about 8 hours when it started acting up. It was running on N/G and adjusting the mixture did not help. I cleaned the points, which did not help, so I left the point box cover off while it was running and noticed that the points would randomly arc excessively when it acted up. Put in a NOS condenser in and the points arced less all of the time, plus it quit the random arcing. It saw another 8 hours of service with no more problems.
As others mention, I would hook a test light to the positive side of the coil to see if you losing power to the coil.
David C.
Old 05-06-2015, 08:35:36 PM
Billy J Shafer's Avatar
Sounds like bad points.
Old 05-06-2015, 10:09:23 PM
BigBlockChev's Avatar
Since it does this on both gas and propane it pretty much can't be a fuel issue. Others have said crappy points, maybe plug wires arcing maybe a loose/poor connection in the ignition circuit somewhere, maybe a relay contact is iffy, maybe a wire is broken inside the insulation, wiggle them all to see if you can force it to happen. Tighten all screws on terminal blocks. My buddy replaced about 10 thermocouples on his boiler before calling me, I replaced it again but then noticed a loose crimp on a spade terminal Cheers Dan
It's always something simple.
The Feynman method , teach it to a kid , then you understand it.
The Following User Says Thank You to BigBlockChev For This Post:
Old 05-07-2015, 10:22:17 AM
Onan Dan's Avatar
Onan Dan Onan Dan is offline
Viking 66 last year about this time my 6.5 NH started acting up like this I had it tuned up and running like a new one it had new plugs points and condenser for 5 days it had me pulling my hair out . Jack DD said it sounds like a bad condenser ? so I put the old condenser back in that goes to the points hit that start switch and it ran like a new one. never gave the new condenser any thought it had less than ten hours on it. OD
The Following 2 Users Say Thank You to Onan Dan For This Post:
Old 05-07-2015, 10:42:56 AM
RSCurtis RSCurtis is offline
I'm with Max, it has an ignition problem.
Old 05-07-2015, 11:12:41 AM
Sir Thomas Sir Thomas is offline
Email Not Working
To measure resistance in the primary circuit,
connect one ohmmeter lead to the positive (+)
terminal and the other to the negative (-) terminal
on the coil. The resistance should be between
3.87 and 4.73 ohms. A high resistance value indicates
an open circuit or poor connection inside
the coil, and the coil should be replaced.
To measure resistance in the secondary circuit,
connect the ohmmeter leads to the two high tension
terminals (see Figure 6-8). The resistance
measured should be between 12,600 and 15,400
ohms. A lower resistance value indicates a
shorted secondary winding. A high resistance
value indicates the coil has excessive internal
resistance or an open circuit. Replace coil if not
within specifications.
The Following User Says Thank You to Sir Thomas For This Post:
Old 05-07-2015, 12:36:51 PM
len k len k is offline
I agree on trying to die. Since it's doing same on gasoline and vapor fuel it's likely not a fuel issue, I say ignition problem.
Check for intermittent low voltage connections first, put a small 12V test light between coil + and engine frame, check to see it stays on steady while engine is trying to die. Then put it across coil and see if it changes brightness as engine tries to die.
Back in the day on cars first thing you do for a problem like this is replace points and condenser, they go bad. Were cheap to replace. With no points in modern cars easy to forget you have to do this periodically with old engines.
The Following 3 Users Say Thank You to len k For This Post:
Old 05-07-2015, 04:49:26 PM
Viking66 Viking66 is offline
Thanks all.
The points I have are fairly new, but I think I have a new set and a Condenser here in my Garage. I now think, since it was pointed out...lol that it is ignition since it is doing it on both fuels.
I will not be able to go to my Camp this weekend, so I will not have a report back until a week from tomorrow. I will let you all know what it was.
Thanks as always!
Old 05-15-2015, 03:10:16 PM
The Winner is..........Condenser. :
That was the first thing I decided to change and got lucky. She purred just like she had been doing before
I truly appreciate all of the suggestions and advice.
As always, this place is Awesome!!!!
The Following 6 Users Say Thank You to Viking66 For This Post:
Old 05-15-2015, 06:06:01 PM
Thanks for letting us know what the outcome was.
2 HP NOVO smoking badly Bob Johnson Antique Gas Engine Discussion 4 08-08-2013 02:46:30 AM
Onan 5cck-3 r13j 3c1b generator commutator brushes arcing badly / no start Toddt Onan Generators 5 12-17-2012 09:06:36 PM
Onan 6.5NH-3CR/16004P Arcing badly from inside generator housing, engine end mronkar Onan Generators 13 11-01-2011 09:48:47 AM
Badly Bent Rod turbo Antique Gas Engine Discussion 5 11-30-2010 02:07:27 AM
Bessemer cylinder badly rusted..... DirtbikePilot Oil Field Engines & Related Equipment 12 02-15-2007 10:10:47 PM
