Badly Bent Rod
this thread has 5 replies and has been viewed 1923 times
Old 11-26-2010, 02:54:28 PM
turbo turbo is offline
Default Badly Bent Rod
I was going through some stuff in my shop yesterday and ran across this rod. 12 years ago I bought two 2 1/4 hp galloway engines. The parts engine had a broken frame and this rod. There are no cracks in this rod but as you can see it is just slightly bent How is this possible with a cast iron rod It is kind of a neat conversation piece but It would be nice to find out how it got this way.
The Following 4 Users Say Thank You to turbo For This Post:
Old 11-26-2010, 03:03:33 PM
Jim Sherman's Avatar
Images: 84
Default Re: badly bent rod
The rod is probably cast or forged steel and has a little more flex and forgiveness than cast iron.
Cool piece!
Jim Sherman
My website
The Following 3 Users Say Thank You to Jim Sherman For This Post:
Old 11-26-2010, 05:18:41 PM
Farmer John Farmer John is offline
Default Re: Badly Bent Rod
you couldnt bend it that way if you wanted to without breaking it
The Following 2 Users Say Thank You to Farmer John For This Post:
Old 11-26-2010, 06:02:21 PM
Tanner Remillard's Avatar
Images: 10
I had a John Deere engine one time that did that too. I opened the crankcase when I was restoring it and the rod had bent about like that. The piston was pushed all the way to the back of the cylinder and about 2 inches farther then it should have been. All we could figure was that it got water in it and when it froze it just pushed the piston back and bent the rod. Hard to believe it did that instead of breaking the head or block.
The Following User Says Thank You to Tanner Remillard For This Post:
Old 11-26-2010, 11:46:19 PM
Frank Y's Avatar
Frank Y Frank Y is offline
Images: 8
Yep, looks like the old hard water in the cylinder trick!
The Following User Says Thank You to Frank Y For This Post:
Old 11-30-2010, 02:07:27 AM
jamest jamest is offline
Probably a steel rod. I made steel for years and one application was for connecting rods, A high sulfur coarse grained steel -- has a lot of give was used for lots of connecting rods.
I bent my bar! Peter Chain Saw Collectors 7 05-01-2009 12:29:17 PM
Badly stuck Briggs 5s Breaker Point Plunger James Wallace Small Air Cooled Gasoline Engines 3 11-07-2008 06:37:58 PM
Bessemer cylinder badly rusted..... DirtbikePilot Oil Field Engines 12 02-15-2007 10:10:47 PM
Bent Rod? Frank P Onan Generators 15 04-05-2006 10:28:57 PM
Repainting a really badly painted engine Bob R. Antique Engine Archives 4 07-29-2004 08:37:56 AM
